Author
Topic: DON'T THROW OUT THAT LIGHT BULB !!! (Read 26639 times)
andrew_k
Melbourne, Australia
You're insane.
Logged
Dragonfly
I cant remember who originally mentioned this...I think it was Jack, but may have been RG or one of the other "Big Brains" around here...anyway, they deserve the credit...I'm simply bringing it to the masses !
Logged
evilpaul
Paul - not really that evil
Great work mate, I've got a huge smile on my face right now. MacGyver would be proud.
Logged
Sir_Ian
you forgot something...They also have Mercury inside them.
So just use a little caution. But this also means you can salvage all the mercury into little globs and make handheld mercury mazes with them. My barber had some of these growing up. You got to get the glob of mercury to flow to the center of the maze...kinda fun.
Logged
Time flies like an arrow, fruit flies like a banana.
Dragonfly
Actually, I didnt forget...I mentioned it on the "please read" page in the gallery ...last line... But its always good to mention it again. at least for the "caution" part. As for the "Mercury Mazes"....I see nothing, nothing....
Logged
Steben
Steven Burvenich
For a moment I thought it was all about incandescent. They tend to behave compressing (non-linear resistance), so I tought: wow the dragon made it DIY! So I was a tad disappointed, although it's super crazy enough on its own  .
Logged
Yes, Fabian Cancellara is the best, but yes still fan of Tom Boonen
demonstar
Brilliant... Just brilliant!
Logged
"If A is success in life, then A equals x plus y plus z. Work is x; y is play; and z is keeping your mouth shut" Words of Albert Einstein
birt
did you also notice that some of those parts are a little underrated for their purpose in those bulbs? and that production and disposal of these light is not nearly as ecological as with normal incandescents? that all of them have something like "max 50°C" indicated on them and ALL exceed that temperature in about 15 minutes?....
so i am really glad that you make them a little more usefull. ;-)
Logged
Renegadrian
Adriano - Rome Italy
Andy, what a thing...Never thought you can make guitar fx out of bulbs... The 13W Overdrive looks like an Electra, Am I wrong? Gotta try those circuits!!!
Logged
Steben
Steven Burvenich
did you also notice that some of those parts are a little underrated for their purpose in those bulbs? and that production and disposal of these light is not nearly as ecological as with normal incandescents? that all of them have something like "max 50°C" indicated on them and ALL exceed that temperature in about 15 minutes?.... so i am really glad that you make them a little more usefull. ;-)
Yes, true. It seems however that large CFl bulbs (+15W) actualy save a lot more, as do large fluorescent tubes (electronics are seperate and control large amounts of lamps). This means: 1. If you want to install "savings", go for CFL bulbs of at least 15W - 20W, or try fluor tubes with seperate electronics. 2. the production, disposal and demolition of small CFl bulbs (7W, 5W,...), each with electronics, is probably overshoot like you said. Each lamp costs as much as a 20W one, yet has 3 to 4 times less energysavings in consumption! For small wattage while still saving, LED's are the better technology or if light quality is important, go for 12V HIR (high efficiency) halogen. As a matter of fact, bulby compact fluorescents already are being questioned in pure economic circles.
« Last Edit: September 01, 2008, 04:14:49 AM by Steben »
Logged
Hanglow
Good idea  I had a 20w GE bayonet one that didn't work as one of the bayonets had broken off, so quickly got to work on it   two transistors are DD127D, couldn't find a datasheet on them 68n X2 6n8 X2 1n5 x2 3.3u 400v electro 5X 1n4007 diodes 1 small power resistor 6 carbon film resistors others - blue diode ? transformer couple of inductors or chokes? now, whoever is first to reuse the pcb gets extra brownie points
Logged
petemoore
As Yet Unrated
So what is the DD127D [three legged jobby in the front of the last pic] ? Any thoughts on what a '2.4mH max' transformer maybe useful for ?
Logged
asfastasdark
Sander de Groot
That's genius! I'll make sure my dad doesn't throw out those old bulbs anymore, I'm gonna be making meself a fluo-fuzz!
Logged
dschwartz
Daniel Schwartz from Chile
hmm those inductors really look good for a couple of whas or resonant filters....
i´ve been wondering for a while what if we use 1 or 2mH inductors in wahs, changing the caps values accordingly for the same freq response..
Logged
Hanglow
That is one of the transistors I assume, just a different form to the standard ones
Logged
DougH
13W overdrive???
Logged
Steben
Steven Burvenich
13W overdrive???
"made of" .... 13W bulb. i guess...
Logged
