Pages: [1]
Author
Topic: How to solder properly (Read 6620 times)
rm -rp ./Matt*
After building a circuit with the solder globbing on the board and not sticking to anything but the soldering iron I had a search on the forum for some soldering techniques. I noticed user darron made a little animation explaining how to, I had a search around the interwebs and found this excellent video which shows how badly wrong I have been soldering all this time. To other beginners, learn to solder properly asap! http://www.tangentsoft.net/elec/movies/tt02.html
Logged
-- keh keh yeh.
Dai H.
might want to try checking out youtube. There are some video illustrations of manual soldering there also.
Logged
asfastasdark
Sander de Groot
Just something to make a note of: When applying solder to a component, you should try not touch the solder to the soldering iron. I did it in the beginning, lots of other people do also, but you tend to get cold joints real quickly by doing this. Besides that, this is probably the best how to solder video I've seen.
Logged
mth5044
Matthew H - PA
Just something to make a note of: When applying solder to a component, you should try not touch the solder to the soldering iron. I did it in the beginning, lots of other people do also, but you tend to get cold joints real quickly by doing this. Besides that, this is probably the best how to solder video I've seen.  I still do that and after well over 15 builds I still haven't had a cold solder joint. Lucky? Probably. So dont do it
Logged
asfastasdark
Sander de Groot
... From what I've heard, you get cold joints quickly. Sorry, all I've ever done is soldered two switches into a guitar and made a killswitch... I don't solder much at all, it's just that I've heard that that causes cold joints... I've never had a cold joint myself, so there you go... but still.
Logged
Minion
Just something to make a note of: When applying solder to a component, you should try not touch the solder to the soldering iron. I did it in the beginning, lots of other people do also, but you tend to get cold joints real quickly by doing this. Besides that, this is probably the best how to solder video I've seen.  I actually do it that way and I prefer it to waiting for the part to heat up before adding the solder...The trick to not getting cold solder joints when doing it this way is to leave the iron on the Part for a second or two longer untill you see the solder actually flow into the Part as opposed to the Solder just sitting arround the Part in a Ball....I notice the heat transfer from the Iron to the part is much more efficient when there is solder on the iron..... Cheers
Logged
Go to bed with itchy Bum , wake up with stinky finger !!
asfastasdark
Sander de Groot
Yeah, you're supposed to tin the tip of the iron for better heat transfer. And by the way I'm no soldering expert, it's just that I read all this stuff all the time  .
Logged
Electric_Death
What do I do when the tip of my iron literally disintegrates while I'm trying to solder?
Logged
DNomis
A good solder joint should only take about 5 or 6 seconds to make with some practice....  Say about 3 or 4 seconds to heat the solder pad/component lead,1 second or so to apply solder,about 2 seconds cool down.....  Make sure the tip of your soldering iron is clean and shiny,apply a little bit of solder to the tip to tin it,wipe the tip on the sponge or brass wool cleaner after tinning and occasionally...  Replace soldering iron tips that look dull and pitted.....
Logged
Pages: [1]
