Pages: 1 [2] 3
Author
Topic: 1: Tools (Read 63080 times)
aron
Administrator
Aron Nelson
1: Tools
« Reply #21 on: October 06, 2003, 01:18:34 AM » |
Hey,
That first one is the one. YEAH, $19.99.
They raised the price a little while ago, but it's back @ $19.99.
I still use it to debug now and then.
It works fine for most of our small circuits. Yes, it doesn't have all the bells and whistles but it works for most things.
Do you have to get another multimeter later? Maybe, and you will probably want to.... but this little guy will work for many projects.
Logged
Mike
1: Tools
« Reply #22 on: March 08, 2004, 12:29:01 PM » |
I'm a total newbie here. Some great info in this forum and I'm going to give the beginner project a try.
Now, I do have basic soldering skills and have tried some basic beginner mods (SD-1 808 mod).
I'm just not sure what kind of Mulimeter I would need. I've never used one before. What do they test?? I've seen ranges of 15 to 42. I don't know what that means. What number should I get?
Logged
my hair is on fire
smoguzbenjamin
Ben Allen
1: Tools
« Reply #23 on: March 08, 2004, 01:02:20 PM » |
Get a Digital Multi Meter. Even a cheap one will do. The instruction manual will teach you how to use it properly and otherwise just post back here  It'll measure at least volts DC, volts AC, resistance and current. Some can test transistor gain and even capacitance!
Logged
aron
Administrator
Aron Nelson
1: Tools
« Reply #24 on: March 08, 2004, 01:21:27 PM » |
The meter I recommened is in the FAQ, but what I look for is:
Auto Ranging (it automatically sets the range on the meter). This is GREAT for beginners.
Most will have the usual, resistance, AC,DC,continuity.
Then the advanced cool stuff for us:
Transistor checker Transistor hFE check Transistor auto pinout identification Capacitance (for checking capacitors).
For all of this, you should expect to pay up to $100.
For one without the advanced stuff (but with auto ranging), probably around $30.
Aron
Logged
smoguzbenjamin
Ben Allen
1: Tools
« Reply #25 on: March 08, 2004, 02:37:27 PM » |
I bought my manual DMM for the equivalent of $10
Logged
slackhammer
beginner
« Reply #26 on: April 14, 2004, 12:49:25 PM » |
what's the best way to get started with parts? is there any way to get a "vaiety pack" of resistors, caps, etc?
I want to do my first build, the "tremolus lune" and want to know the best way to go about getting the parts.
Logged
PB Wilson
1: Tools
« Reply #27 on: April 14, 2004, 03:45:23 PM » |
You can get 500 resistors in a ton of different values from Radio Shack for about $11 (if I recall correctly).
Steve at Smallbear sells variety packs of caps as well: 100 film caps for $13.95 32 silver mica caps for $13.00 55 electrolytic caps for $11.50
So, for about $50 you can be well stocked up for most of the projects you are likely to come across. After wasting a lot of money buying a few caps here, a couple resistors there, I wised up, bought the packs mentioned above and now I am set for a good, long time.
Logged
FisTheGoon
1: Tools
« Reply #28 on: December 05, 2004, 07:51:13 AM » |
What wattage is good for soldering? cause at certain wattage componnt might burn or damaged. thanks :?
Logged
Hal
1: Tools
« Reply #29 on: December 05, 2004, 04:39:04 PM » |
a 15-25 watt iron is deff. high enough. Up to 40 watts your pushing high heat. I don't recomend anything above 40 watts.
If possible, get a variable temperature iron, and practice before you set to anything real.
Good luck :-D
Logged
Stony Brooklyn's where its at, yo w00t w00t
JLM
Re: 1: Tools
« Reply #30 on: October 17, 2005, 12:03:37 AM » |
All I have right now is a 50W soldering iron...  Will it work or it's just too much power? Do I really need to buy a less powerfull one, even if use sockets for ICs?
Logged
niftydog
Hey you're a dog, a BIG dog, a nifty-keen-type dog
Re: 1: Tools
« Reply #31 on: October 17, 2005, 12:16:49 AM » |
is it adjustable in temperature?
It's not too much, even if it's not adjustable, but you do have to be carful not to allow too much heat to be transfered to the components and circuit board.
What you might find is that the tips are too large. Often with large soldering irons there's limited replacement tip sizes, and a tip that's too large is effectively useless.
Logged
niftydog Shrimp down the pants!!! “It also sounded something like the movement of furniture, which He hadn't even created yet, and He was not so pleased.” God (aka Tony Levin)
guythmike
Re: 1: Tools
« Reply #32 on: February 05, 2006, 02:35:38 PM » |
does it matter what type of solder you use? there's different types, like silver bearing and rosin core and such. which is better?
Logged
theundeadelvis
Ahren O., Bloomington, IN
Re: 1: Tools
« Reply #33 on: February 05, 2006, 02:49:42 PM » |
A lot of folks here swear by 63/37 rosin core solder. I use 60/40 in a .032 diameter (from Radio Shack) and its work great. I have a roll of 63/37 but it's in a .050 diameter and its way too thick for my liking. I plan on getting the 63/37 in a smaller diameter and trying it. Anyway, a thin rosin core (with a flux that either doesn't need cleane or is easily cleaned) soldereither 60/40 or 63/37 is what I recommend.
Logged
If it ain't broke... ...it will be soon.
guythmike
Re: 1: Tools
« Reply #34 on: February 05, 2006, 03:09:03 PM » |
thanks a lot.
i'd say "i'm new to this" like everyone else, but i figure it's pretty obvious.
Logged
Dannycasio
I have a Weller Iron 60W/230V (W60D). Is this too powerful?
Logged
aron
Administrator
Aron Nelson
If it's a fixed wattage, then I would say yes. Radio Shack or your local electronics store will have a lower wattage/pencil type iron that would be better suited. Just tell them that you are working on PCB and smaller components and they will point you to the right tools.
Logged
UP-G
What is a desolder braid and how does it work  I've never worked with it ...
Logged
ST_ELM
Hi all , Im newbie here, just want to ask , bout the size of perfboard .... thaks in advance ...
Logged
aron
Administrator
Aron Nelson
What is a desolder braid and how does it work  I've never worked with it ... The way I've used it is to press the braid against the solder joint and heat. The braid will "wick up" the solder. Then remove the braid and the solder joint will be pretty clean. That being said, I use those plunger type solder removers for most of my work.
Logged
Pages: 1 [2] 3
