PIC Microcontroller - Max Current Source Question.
Started by demonstar, October 08, 2008, 10:42:23 AM
demonstar
The datasheet for a PIC I am using says that the maximum current sourced from any output is 25mA and a total of 250mA into the VDD pin. If I tried to source more than the allowed total 250mA (well prob 240mA by the time the power for the running of the PIC is taken off) from the chip would it allow me to do so and damage the chip or not allow me to do so and just cap the current at the max? In otherwords will it prevent anymore than the max. current (250mA) being taken into the VDD pin or will it take more than that in and ultimately kill itself?
Thanks.
"If A is success in life, then A equals x plus y plus z. Work is x; y is play; and z is keeping your mouth shut"  Words of Albert Einstein
mutant_guitar
if the chip doesn't die, it will probably not function properly. i've had this problem before when hooking a 5v uc to a 3.3v FPGA. it didn't damage either, but some weird stuff  happened. i don't know how the PIC will handle being overloaded, but i wouldn't try to find out.
if you need more current than the PIC can provide, then you should look into adding some sort of transistor switching circuit to your outputs.
demonstar
Quotef you need more current than the PIC can provide, then you should look into adding some sort of transistor switching circuit to your outputs.
I'm making a experimenting board for PICs. I'll have a board with velcro on that I can velcro modules to. The modules will include oscillators, LED arrays, LCDs, a motor and breadboard etc. I just know this will be something I'll use for a while to come. I'm documenting it (Like an operating manual) so when I come to use it in the future when my mind isn't so fresh, I know exactly what it is safe to do with it and what it is not safe to do with it. I'm just trying to work out if I can overload it or if it prevents that so I can document it. :icon_biggrin:
mutant_guitar
lol, PICs are cheap, might as well blow one up.
anyway, sounds like a neat little project.
Inventor
Quote from: demonstar on October 08, 2008, 01:34:35 PM
Cool, demonstar, I'm working on a similar project called EChucK.  It's a PIC-based modular synthesizer that can be used for making guitar effects.  It's open-sourced hardware if there is such a thing so you can copy my work if you like, or you might want to contrubute.  In fact, I think I'll post about it in another thread.  Great minds think alike!  Cheers!
