Best OD/Distortion for humbuckers
Started by AM, November 07, 2008, 05:41:09 AM
DSV
Jus a bit, which IMHO is good for placement in a mix, but in case you don't like it you can simply rework the output filters.
AM
Ok, this is an update.
I followed Aron's and John's advice and reworked a Llama circuit once more. It ain't really a Llama anymore but it's still a 4049. It sounds pretty good! It's on my board and I will test drive it for sometime. The Big muff I leave it stock for now. I might tweak the mids a bit later.
Stan suggested to try out a DS-1. I was always sceptical about those ones, BUT.....I found an old Boss ME-5 lying in my studio. There are a couple of overdrives and a distortion in there. The distortion I believe is pretty similar if not the same as the DS-1. I gave it a try and much to my surprice I really liked it!!! I usually set my amps a bit dark for rhythm so when that thing kicks in for lead, the extra high content is very wellcome. Because I always play humbuckers, it didn't get ovberly bright as it might have been the case with single coils. I liked it the best at a lower gain setting. At higher gain it didn't do much for me. I think I will pick up one of those in the single pedal format and mod it.
DSV, your preamp seems like a really cool project!!! I think I will skip building a stand alone BSIAB and built your preamp at some point in the near future.
Thanks everybody for your input.
modsquad
Told you so. :icon_mrgreen:
I modded mine, so you may want to try some of the mods.  If interested I will have to go back and check what I did. ???
"Chuck Norris sleeps with a night light, not because he is afraid of the dark but because the dark is afraid of him"
Ben N
+1 on the DOD250/Distortion+ suggestion. I find these top go great with HBs, much better than SCs (IMHO). Again, there are so many variations/mods/variants (most notably the Voodoo Lab OD), that I suggest you read up on it, pick a configuration based on other people's descriptions, and then breadboard it so you can try stuff out and tweak to taste.
DSV
Quote from: AM on November 10, 2008, 06:52:19 AM
Thanks! And good luck with the tweaking!
