Help on decision for speaker sim
Started by cb951303, November 21, 2008, 06:50:58 AM
cb951303
Hello,
I'm in a need of speaker/cab simulator and a DI box.
Heres my dilemma: I can buy one these: http://pro-audio.musiciansfriend.com/product/Behringer-GI100-UltraG-DI-Box?sku=150934
Or I can build a LXH2 speaker sim and get a cheaper DI box.
Did anyone try LXH2 before? How does it sound? Is it any better than behringer's cab sim?
Thank you
DougH
Can't comment on the Behringer but I know some people swear by it, esp for the price.
IMO the full-blown LXH2 speaker sim is overkill, but the "LXH2-Lite" would be a feasible project. (I'm not sure which one you were referring to.)
If by "DI box" you mean something that converts from the high impedance of the guitar pickups to the low impedance needed to plug into a console- just about any of the DIY speaker sim circuits you see will accomplish that. Most of these circuits use op amp based active filters and will drive plenty of current for direct injection into a line level input. They may or may not be technically "line level" with respect to voltage amplitude (1v p-p?? Can't remember) but they have enough of a low impedance drive to work just fine.
dschwartz
may i recommend my baby?
http://www.diystompboxes.com/smfforum/index.php?topic=70445.0
it´s an adjustable cabinet simulator..i love it..
you can add an extra dual opamp to make a balanced output..
Tubes are overrated!!
http://www.simplifieramp.com
cb951303
#3
Quote from: DougH on November 21, 2008, 07:33:01 AM
Currently I use IR cab sim softwares and I find them really really close to the real thing but recently I decided not to depend on a computer since its not portable hence I need a decent cab sim. I don't care if it's versatile or not. Only 1 working cab sim is enough :) For the price of behringer I'm just not sure if it's worth to spend time and money on a lxh2-lite build :) what would you do?
Also thanks for the DI info
cb951303
Quote from: dschwartz on November 21, 2008, 07:39:52 AM
Great project. Sound samples are good. Do you sell pcbs?
cb951303
DougH
Quote from: cb951303 on November 21, 2008, 08:07:53 AM
I've heard a lot of good things about IR models and that is supposedly the way to go with speaker sims. If not already, I would think at some point someone would build one of these that fits in a box, maybe via DSP or etc. The Behringer unit and all these diy circuits are just analog active EQs that mimic speaker freq response curves. They are pretty simple in comparison.
And I forgot, with DI if you are looking for balanced line operation that will require a little more work but Daniel included that in his project.
cb951303
http://www.richardbrice.net/hot_lamp.htm
anyone tried this? sound samples are perfect. better than any diy speaker sim that I listened so far ...
cb951303
It's hard to believe a small circuit like this would do such a great job and not heard by anyone here :) ? I'm starting to think I got it wrong. This is a traditional speaker simulator right? the one that you place between a preamp and mixer?
jonjon
john
dschwartz
Quote from: cb951303 on November 23, 2008, 04:50:02 PM
nope.. as i see..the input is the speaker output of an amp..then it goes to the mixer.
cb951303
Quote from: dschwartz on November 24, 2008, 07:50:24 AM
it's the same thing  ::)  what I meant was this circuit actually replaces a speaker cab right? have you listened to the sample, i found them very realistic, what about you?
alfafalfa
And there's a warning that if you blow the lamp  your amp is without a load : so you're in for big trouble !
Alf
cb951303
Quote from: alfafalfa on November 24, 2008, 12:58:09 PM
Alf
yup, I'm gonna use it between my preamp (basically an effect chain) and speakers so I don't have to worry about load problems...
BTW, I've just received service docs of Red Box Classic from H & K. This is a speaker simulator/DI box. The service documents have the full schematics and a ready to solder PCB layout  ;D so I may go with it for the sake of laziness. I also heard its a pretty decent speaker sim...
dschwartz
Quote from: cb951303 on November 24, 2008, 02:24:40 PM
Alf
i´m not sure if it will work with a preamp output..it´s a different thing...
