Geofex Low Fidelity / Telephone / Noise Pedal - Layout proof
Started by chi_boy, January 30, 2009, 12:44:16 AM
chi_boy
Hi all,
I was hoping I might trouble some of you to proof a layout for me?
This is my first attempt at a layout and would appreciate a critical review before I try etching a board.
The pedal is the Low Fidelity / Telephone / Noise Pedal posted at http://www.geofex.com/FX_images/lofi.gif
The schematic with resistor numbers and two views of the layout are shown below.  The layouts are the same, only the components are darker or lighter for viewing the traces.  I used DIY Layout Creator, but it's new for me, so I may not be using all the best tools.  Sorry if this isn't the best way to view the layout.
Also, the schematic is posted with R.G.'s permission.
Thanks for any help.
George
GroupNameValueQuantity
CapacitorsC1100uF1
CapacitorsC247uF1
CapacitorsC3, C100.1uF2
CapacitorsC4, C5, C7, C60.01uF4
CapacitorsC80.01, 0.1, or 1.0uF1
CapacitorsC91uF1
DiodesD11N40011
IC'sIC1, IC2TL0722
PotentiometersVR1100K1
ResistorsR11, R19, R17, R13, R9100K5
ResistorsR12, R10, R856K3
ResistorsR16, R14, R18, R1551K4
ResistorsR2, R147K2
ResistorsR20, R510K2
ResistorsR2122K1
ResistorsR22, R3, R4, R241M4
ResistorsR23100R1
ResistorsR7, R65.6K2
TransistorsQ1, Q22N50882
"Great minds discuss ideas, average minds discuss events, small minds discuss people." — Admiral Hyman G. Rickover - 1900-1986
The Leftover PCB Page
chi_boy
Well, I've checked this several times and it looks good to me. Time to etch, I guess. The only thing left is a board for a rotary switch to add some versatility to the filters.
sevenisthenumber
Skruffyhound
chi_boy
Quote from: sevenisthenumber on August 17, 2010, 10:55:39 AM
Did this work? I would love to build!
It worked as advertised, but there was a minor issue with the noise section.  I'll look everything up and post the changes tonight.  The problem was a resistor value, not with the layout itself.
This is the thread about the noise problem: http://www.diystompboxes.com/smfforum/index.php?topic=81197.msg672208#msg672208
I also have a version on my breadboard right now that works even better.  I used Mark Hammer's suggestions from this post and it made the thing a lot more versitile: http://www.diystompboxes.com/smfforum/index.php?topic=25185.msg164559#msg164559
I'm also trying to add some different noise options.  Like white, pink, brown, and some crackle noise.  The white noise varients were easy.  Now I'm looking for something that will gererate a nice whine.  I also wanted to add a mixer to replace the panner so that the new noise sources could be mixed as desired.  The panner works as it should, but I don't like how it cuts the guitar volume as it adds the noise.  Haven't got to that part yet though.
George
bancika
<pride>
cool, that's one of the prettiest layouts drawn with my DIYLC, nice work man!
</pride>
chi_boy
Quote from: bancika on August 18, 2010, 09:16:27 AM
<pride>
</pride>
Wow.  That's means a lot coming from "The Man."  Thanks for the kind words.  That was actually my first attempt at a layout.
For the others asking about verification, the circuit worked for me as shown.  The final changes are wrapped up in this post:
http://www.diystompboxes.com/smfforum/index.php?topic=81197.msg673042#msg673042
The DIYLC file is available here: http://home.comcast.net/~gprause/Telephone_4.diy
You may have to right click and save.
The DIYLC file has all of my final changes.
Cheers,
George
knutolai
I know this thread has been inactive for quite some time. The schematic has 404ed. Could you possibly repost the drawings somewhere? Im very interested in this circuit!
runmikeyrun
Bassist for Foul Spirits
Instagram: @torcheffects
Dislikes: old women
chi_boy
knutolai
chi_boy
Quote from: timd on April 17, 2012, 09:26:38 PM
Any soundclips?
Sort of, but not quite.  I didn't like the original, so I added some of Mark Hammer's ideas and came up with this:
http://home.comcast.net/~gprause/LOFO_MOD.gif
This is a clip of the modified pedal:
http://home.comcast.net/~gprause/LOFI_Sound.mp3
This is still testing, so it's not in a box and I don't have a switch on it.  The clips is as follows:
  Treble and bass set to max - No cut
  Treble cut at MAX
  Bass cut at MAX
  Treble and Bass cut at MAX
  Bass cut at max, treble cut at 50%
The problems with it right now are:
  1) I made a different noise section and haven't fully tested the mixing part.
  2) There is a volume drop as the controls are maxed.
I think the volume drop can be fixed by making R16 a pot, but again haven't tried it yet.  I like the noise section on the breadboard, but just need to test that mixing part.
chi_boy
Thanks, the flavor was intentional.  I used all ceramic caps and 1458 op-amps.  I tried it with better caps and TL072's and it worked fine too, just not the sound I was after.
timd
I think I may attempt a sound that's in the same ballpark via circuit-bending then making a guitar pedal out of that mess. I post back if I have success. I'm really looking for a white/pink noise generator...
