java boost trimpots
Started by bagudan, March 12, 2009, 07:15:40 PM
bagudan
Hi . apparently I had luck building the java boost from torchy´s layout. PNP transistor, negative ground, and no noise at all? Surprisingly nice!!!
I set the 100k trimmer so that the collecter voltage is now 7 volts... allready sounds sweet. But what about the second (10k) trimmer. What is this for? Should i trim it to my liking by ear.? Or what do I do?
_Kasper
chi_boy
Sorry I can't help, but where did you find Torchy's layout?  I have found reference in several threads (Found with the search button) but can't locate the actual layout.  The usual link is dead and it doesn't seem to be available anymore.
Cheers,
George
"Great minds discuss ideas, average minds discuss events, small minds discuss people." — Admiral Hyman G. Rickover - 1900-1986
The Leftover PCB Page
kurtlives
Quote from: chi_boy on March 12, 2009, 09:44:02 PM
Cheers,
George
All of his layouts have been pulled. Unless you saved copies or can get others saved copies your going to be layout-less...
My DIY site:
www.pdfelectronics.com
LEON.01
chi_boy
Quote from: kurtlives on March 12, 2009, 10:12:31 PM
Were they pulled for a reason?  By request perhaps?  Just curious.
kurtlives
Was kinda for a reason..he has a long history of issues with forums and such. Best not get into it, its long anyways. Just enjoy the layouts that are out there ;)
My DIY site:
LEON.01
I got copies of most of his layouts just before they were pulled! Anything else you need, just give us a poke!!  ;D
Built this a while ago. Infact it was the first build i ever got working! Cracking pedal! Just didnt have an enclosure so it hasnt really seen the light of day!
I will re-connect the DC jack and have a play around with it, Should be able to tell you what that trimmer does then!  ;)
bagudan
chi_boy
Quote from: bagudan on March 12, 2009, 07:15:40 PM
_Kasper
After doing some research, I guess I can help a little after all.  Go to GeoFx and search there for the Rangemaster article.  He explains how to use the two trimmers to bias the tranny.  If you buy an OC44 from small bear though, he already does the work and you can drop in a fixed resistor.
My nagging question is why use a tone control.  This thing is a treble booster, why cut trebble after boosting?  Just trying to understand, but for the moment it doesn't make sence to me.
GP
bagudan
thanks...guess i´ll read the geo article again. I thougt only one of the trimmers set the bias voltage... unsure about the other one. Maybe because i installed a 10 k multiturn(what I had)....nothing really happens.
The tone control. I dunno? Maybe it´s just there if you want to to cut some of the treble of. I like it all the way up for lead. But maybe it could get handy to roll of some treble in other situations.
bagudan
Yeah, seems you were right(George P) Both of the trimmers are for biasing the collector.
Thanks-
chi_boy
Quote from: bagudan on March 15, 2009, 12:22:23 PM
I suppose the Java boost could do double duty as a mid boost or bass boost when the tone is rolled off with the 3 position switch in the mid or full positions respectively.
kurtlives
Does anyone have a schematic for this?
My DIY site:
chi_boy
Quote from: kurtlives on March 15, 2009, 08:50:52 PM
Found this somewhere, but not sure exactly where.
