Author Topic: Single Row sockets available (can be snapped!)  (Read 11550 times)
aron
  • Administrator
  • Aron Nelson
« on: March 16, 2009, 03:12:06 PM »
10 socket single row - can be snapped to size. Available in the store as a grab bag. I think you will really like these!
http://diystompboxes.com/zencart/index.php?main_page=product_info&products_id=33
trixdropd
  • member2
Re: Single Row sockets available (can be snapped!)
« Reply #1 on: March 16, 2009, 06:00:14 PM »
They certainly look cool!! Order placed. :) :) :) :)
aron
  • Administrator
  • Aron Nelson
« Reply #2 on: March 16, 2009, 07:41:23 PM »
COOL!
kbibs
  • member2
« Reply #3 on: May 04, 2011, 09:24:08 PM »
I purchased a set of these and they appear to be nice quality but they seem too big to fit into the holes of a GGG ITS8 pcb I purchased. Do I drill the pcb slightly bigger or file the pin of the socket? The board appears to be single sided so I think it will be ok. If it was double sided or multi layered I'd be afraid to.
Thanks for the help!
Govmnt_Lacky
  • more
  • I'M ONLY GETTING CLEAN OUTPUT!!!!
« Reply #4 on: May 05, 2011, 08:39:27 AM »
If you have drill bits that are small enough.... and you have a dremel tool that works well... then you should drill the board a bit bigger to fit the pins.
I am surprised that these will not fit into the holes   ???  I have used standard 0.1 spaced inline sockets on JD's boards before with no problem.
Good Luck  ;D
for an amount of ‘up to and including my life.’
Hides-His-Eyes
  • Poster2
« Reply #5 on: May 05, 2011, 09:13:23 AM »
Note: only the bottom bit of the sockets needs to go through to the other side, not the whole metallic bit.
kbibs
  • member2
« Reply #6 on: May 05, 2011, 09:05:50 PM »
Thanks for the replies. I've used others before that had a straight pin without a problem. These have a tapered pin with one flat side which fit in the hole just enough for the pin to show through the other side. So yes I could solder them in that way but they just seem to stick out quite a bit. Yeah come to think of it I probably don't have a drill bit that small, oh well! I was just curious if others noticed the same thing and had a better solution. Thanks!
