TOPFET???
Started by m_charles, April 09, 2009, 05:43:27 PM
m_charles
Hi!
I'm trying to replace a K118 "topfet" transistor. It looks just like any 3pin tranny, but the only replacement I could find was $21.00 for one!
First, what's a topfet? And #2, does anyone know a sub?
I'm trying to revive an Ibanez DL10 (my favorite delay-digital or analog). It's having switching issues. It locks up "on" but only a tiny signal comes through, then sometimes it works fine. I think a bad FET. Is this a good assumption?
Any help is appreciated.
thanks,
Chuck
Taylor
"Temperature and Overload Protected Field Effect Transistor"
Do you have the schem? It would probably help in finding a replacement. Not knowing anything about the circuit itself, stompboxes don't usually create enough heat to kill components, so I wonder if a regular FET would do the job?
Minion
If all else fails you can allways convert the pedal to True bypass switching.....
Go to bed with itchy Bum , wake up with stinky finger !!
anchovie
The DL-10 is supposedly not too different to a DL-5, for which there is a schematic here: http://experimentalistsanonymous.com/diy/Schematics/Delay%20Echo%20and%20Samplers/Ibanez%20DL5%20Delay.gif
The FET used in the switching doesn't have a part number specified, so I suspect any N-channel JFET will do the job. I doubt the K118 (a.k.a. BUK118) was chosen specifically for this job - it may well have been that Ibanez had a whole stash of them for whatever reason and just wanted to use them up somehow.
Jered
  I think 2SK184 is very close and available.
