Is the 808 clone any better than a TS-7 that has had the 808 Mod?
Started by scottjge, April 27, 2009, 12:06:21 PM
scottjge
I have a TS-7 that has had the 808 Mod, but it still isn't the the sound that I am looking for. It has a fuzz sound to it. Is the Cloned 808 any different ? I am looking for a pedal that has just a slight OD to it, something like a tube amp just on the verge of break up. When I used to play out in a band and used my tube amp I could get that sound with no pedals but now that I only play in the house with no band I can not get that sound unless the amp is turned up and it is loud. So I bought a TS-7 and modded it to a 808 but still doesn't sound good. First of all , even with the drive turned all the way down it has too much distortion, and that distortion sounds more like a fuzzy sound. I am thinking about making or buy a 808 clone kit from guitar gadgets but don't want to waste my time nor my money if it is going to sound the same way. Maybe I am looking in the wrong place, maybe I should be looking at a different stomp box, I don't know.
What are your opinions that have had  experience with the 808. Maybe what I am looking for can not be re-produced at normal room levels. I have no  idea and am looking for some guidance.
Any ideas, suggestion, or advise would be greatly appreciated.
:icon_question:
Glenn S
earthtonesaudio
I have a TS7 with the "808" and several other mods.  The "808" mod made no audible difference (to my ears at least).
A couple suggestions:
-make sure the switch is set to "normal," not "hot"
-the pedal sounds best going into a not-so-clean amp
-getting a tube sound out of a stompbox is difficult if not impossible
Most of the clips I've heard that make the TS series sound good are feeding into a tube amp.  It's not really a "tube sounding" pedal on its own, but rather a tone shaping/compressing pedal that makes your amp distort in a nice way.
Joe Hart
I think the charm of a Tube Screamer is when you're pushing a "fired up" amp. I doubt that you can get that same tone with a TS into an amp only turned up to "2" or so. But I could be wrong.
-Joe Hart
Joe Hart
Earthtonesaudio beat me to it! And with better info!
-Joe Hart
scottjge
Thanks for the reply. I figured that it wasn't possible to that sound out of a stompbox, because if it wasn't everyone would have one and would be the hottest selling box out there.
I will have to do some experimenting to get a more decent sound. I am going to put the TS-7 on ebay and I will make my own TS. As a matter of fact, I am getting rid of all my bought stompboxes on eBay. So be looking there if you are in the market for store bought stomp boxes.
Thanks for your input.
Glenn
Glenn S
scottjge
I have posted what I have for sale or trade in the "Sale or Trade" section on this forum, for anyone that is interested.
Glenn S
KorovaMilkBar
i would suggest a dod 250 clone with assymetrical clipping (2 Ge, 1 Si). it definitely has a nice warm tube sound for whatever reason, i am not sure why exactly. but to me it sounds great. mine runs a little too glassy and bright on my brigde humbucker so you might some sort of mod to smooth out the high end (thats what im trying to do). so ya i would suggest checking it out and if i can record some sort of sample i will put it up here.
aziltz
have you tried anything with cascaded jFets?  IMO, way better sounded than any TS could hope to be.
scottjge
Thanks for your suggestions.
No I haven't tried any projects yet to make what I want. I am new to the list and am just getting into building my own stomp boxes and finding my own sounds. After I sell some of my stuff that I had when I was in the band, I will be able to buy some parts and components and start making and tweaking. So far I have had a blast reading and learning about my new hobby to be. Who would have thought it at 56 years old.  ???
Glenn S
MattXIV
The 808 and 7 are very close based on the schematics I've seen, so I wouldn't expect any but very subtle differences in sound.  The 7 has the same clipping and tone stages as the 808 with the addition of a switch that changes the frequency response of the clipping stage.  Beyond the switchable frequency response, the output buffer is different, but that's probably what you modded.  The one advantage of a clone would probably be being able to use mechanical switching instead of the transistor switching in the stock pedal.
FlyingZ
Quote from: scottjge on April 27, 2009, 12:06:21 PM
If you can find a vintage JRC 4558D it will sound richer.
grolschie
Change the IC perhaps? I like the sound of a TS-7 with a TL072 stacked with a TLC2262, and asymmetric MOSFET clippers (body diode) and other tweaks.
scottjge
No all I have is a RC4558P. I have been looking at the Fat Boostered. It looks like it may do what I want, may have to modify it a little though.
Glenn S
grolschie
As far as 4558's go, the Texas Instruments RC4558P is supposed to be pretty decent isn't it? Isn't that one of the ICs that the TS-808 with produced with?
Have you actually heard a real TS-808? It might not be the pedal for you? What about building a LTD Silver? I haven't built one, but it's a nice low gain OD from what I read.
Paul Marossy
I don't really have anything to contribute other than to say that the one pedal I have that consistently gets used is my TS808 clone.
FlyingZ
Quote from: grolschie on April 27, 2009, 07:09:58 PM
The RC4558P sounds just like the stock TA75558P and the vintage RC4558P seems just slightly louder. The vintage JRC 4558D is loud with lower gain and less high end.
I returned an 808 reissue without looking inside, it sounded terrible.
