danos screamer lab
Started by 23, May 09, 2009, 12:04:59 PM
Ok guys I got this monster working, boost, fat, clipper(s), stacked opamps, mid hump mod, clean up mod, and of course vol, tone, gain... but heres my one little freakin problem I cant get the led to work on the boost...I know WTF a little led... well its bothering me. I tried 3 different leds, different hook up arrangements with alligator clips and soldering but cant get it to work....I used a PCB so my board grounds are gone, where do I need to ground this thing? any help???
thanks scott s
put it together, now take it apart
biggy boy
Got a link to the schematic and board layout??
aziltz
ground it with an extra wire to a jack...
23
tried the extra jack wire, nothing....
beavisaudioresearch.com/projects/ScreamerLab?
biggy boy
Quote from: 23 on May 10, 2009, 09:32:52 AM
Your link didn't work
this one should
http://www.beavisaudio.com/projects/ScreamerLab/
23
thanks , just scroll down to the wiring diagram and find the boost mod...
23
I just need a little freakin help, jeez, sometimes its like pulling teeth on here... seems some people get high and mighty ahhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh!!!!!!!!!!!!!!!!!!!!!!!!
kurtlives
Can you confirm that your switch is actually working? DO a continuity test with DMM.
Got a limiting resistor?
Got the anode and cathode correct way round?
My DIY site:
www.pdfelectronics.com
MikeH
#8
Quote from: 23 on May 11, 2009, 04:52:46 PM
People here aren't getting "high and mighty"- maybe they just don't understand your question.  Personally, I sort-of feel if you're able to put together that entire screamer lab, you ought to be able to figure out how to wire an led, and if you can't I probably just don't understand what you're asking.  It just doesn't add up.  That's why people aren't answering your question.  It's like saying "I just rebuilt the engine in my car, and I can't figure out where to put the oil..."
But in case I'm wrong.  Center pole of the switch connects to ground. then connect the proper outer pole the negative (flat) side of the led, connect the other end to a resistor (I can't stress how important this part is, and if you've forgot to, this is most likely your problem) and then to 9v+
cpnyc23
whoa.  i think you need to walk away from the project and clear your head.
-chris
"I've traveled the world and never seen a statue of a critic."    -  Leonard Bernstein
svstee
Did all the LED's you tried come from the same batch? If so, have any LED's from said batch worked for you in the past? Try just the LED (and a resistor) with a battery. All I got, sorry.
Andi
Quote from: MikeH on May 11, 2009, 05:49:10 PMPeople here aren't getting "high and mighty"- maybe they just don't understand your question.
Ayup. It's something to do with an LED but I have no idea what. Presumably this makes me high and mighty. I've always fancied being high and mighty.
trendyironicname
..i just wanna be high..
There are 10 types of people in the world, those who understand binary, and those who don't.
MoltenVoltage
MoltenVoltage.com for PedalSync audio control chips - make programmable and MIDI-controlled analog pedals!
KorovaMilkBar
Quote from: trendyironicname on May 11, 2009, 06:37:53 PM
(cue "i wanna get high" by cypress hill)
oh whatcha miss this?/ you got ta bare witness/
catcha ho, and anotha ho/ MERRY CHRISTMAS!!!
:icon_cool:
23
sorry for the out burst Im having some other problems at this time and things are starting to get destructive........ thanks everyone
23
you know how things can be if you look to hard or life begins to bear down on the psych and meds stop working etc etc etc
reel me out then cut the string
