Guitar Splitter Box
Started by cps, May 31, 2009, 07:52:17 PM
Paul Marossy
QuoteSo what exactly does the pedal do?
It takes a single input and splits it into two outputs so you can route the signal thru two different effect chains and then combines them again into a single output. It also has a blend control which serves as a mixer between the two effects chains.
Ben N
Very impressive Paul--you don't waste any time. I'm lazy. I have an LS-2, so I never bothered with building such a device, even though I'm pretty sure I'd enjoy using it.
Paul Marossy
Quote from: Ben N on June 04, 2009, 01:14:22 AM
It didn't take too long to make it. I already had a lot of the work done on the enclosure. It just needed to be reworked a little bit.  :icon_wink:
