How to wire a 3pdt toggle to move a clean boosts position on a looper???
Started by sevenisthenumber, July 01, 2009, 06:15:09 PM
sevenisthenumber
I have a 4 loop, true bypass looper that has a clean boost at the input.
Its like this:
I just wanna install a little toggle to flip the position of the boost for pre / post boost.
Any help is much appreciated!
Processaurus
H, there is an article at GEOFEX.COM called "juggler" that shows routing like you're after.  Boosts are so easy though, you could throw together a 2nd one fairly easily?
MikeH
There's a wiring diagram at the end of this thread:
http://www.diystompboxes.com/smfforum/index.php?topic=77298.msg634916#msg634916
In you case, one switch would represent the switch for your boost, and the other represent a string of switches for your loops.
sevenisthenumber
