SHO before a Crunch Box (There is a weird hum when both are engaged?)
Started by sevenisthenumber, July 06, 2009, 08:53:37 PM
sevenisthenumber
I have built the  MarkM layout for the Crunched Box along with a Zvex SHO (Andrew Carrell layout) in one enclosure, two footswitches. They both work great but when they are on together there is a strange hum in the background.....? The SHO is pre crunchbox. What could be causing this?
sevenisthenumber
I had been using 9v power supplies like the BOSS and EH one... I just used a fresh battery and it isnt happening???  Anybody know how to fix this?
Toney
Sounds like a grounding issue, assuming they both work OK independently.
How's the power? Did you include some filter caps?
sevenisthenumber
okay....   i removed the led's positive wire from the 9v jack and it goes away. With a battery this noise isnt an issue??? ONly with the adaptors...
They work great independently with the led's but not together???
sevenisthenumber
MikeH
What is the value of you current limiting resistor for the LED?  Just curious...
  Duplicate post fodder  :icon_smile:
sevenisthenumber
Quote from: MikeH on July 07, 2009, 12:19:10 AM
1k metal film
  First, have a capacitor across the power rails, a BFC, 100uf should cover it.
  Then you could try reducing the current through the LED by increasing the 1k, this will tell you if increased current = increased ripple.
Toney
Yeah, like Pete said.
Another thing that could possibly help... having the current limiting resistor on the neg side of the LED if you don't already.
Also... just try another LED!
frokost
I had the same issue recently. A 100 R in series with + and a 100uF to ground solved it.
