Small Bear Laser Waterslide Decals... Compatible Printer?
Started by F.F.T., July 13, 2009, 05:39:52 PM
F.F.T.
I went to my local Kinko's print shop to get some of these printed and they jammed the laser printer and were ruined.  They tried two different printers - I think they were both Xerox brand (at least one definitely was).  The tech put the printers on the the thickest paper setting, too.
Anyone know what brand of printer is definitely compatible with the Small Bear Decals?
tiges_ tendres
Try a little tenderness.
liddokun
I've used them with my HP (Hewlett Packard) printers and they work fine.
To those about to rock, we salute you.
.Mike
Xerox printers function differently than most laser printers. They use blocks of solid toner that is melted before being applied, rather than powdered plastic-based toner that is applied and then fused. This could be the reason why the didn't work.
I would try a true powdered toner based printer. :)
Mike
If you're not doing it for yourself, it's not DIY. ;)
My effects site: Just one more build... | My website: America's Debate.
F.F.T.
Quote from: tiges_ tendres on July 13, 2009, 06:07:26 PM
Did you take off the protective sheet first?
If by that you mean the tissue paper on top, yes I did.
tiges_ tendres
