Putting XLR In and Outs on a Tubescreamer?
Started by sevenisthenumber, July 23, 2009, 10:48:19 PM
sevenisthenumber
I want to build a tonepad overdrive but only have xlr in and out so it can be used for vocals..... What am i looking at here with impedance, wiring, issues?
Ripthorn
Microphones are very low impedance, so I am not sure that matters (since the input impedance will look even larger than it does to a guitar).  The big problem is that in a microphone, two of the xlr pins are signal, but they are out of phase.  You would need to have some way of either inverting the phase of one channel, or take only one channel in and then on the out, put in a simple transistor phase inverter and send the signals on the output.  Of course, that means that you are essentially losing the advantage of a balanced signal going from mic to your box.  Should be doable, but there are modifications needed.
Exact science is not an exact science - Nikola Tesla in The Prestige
https://scientificguitarist.wixsite.com/home
hoostavah
maybe build a seperate box for the mic signal handling? I dont know jsut trying to come up with a solution that might help.
John Lyons
You need a mic preamp to come before the TS and the transformer and or impedance matching before and after as well.
Any dirt added to mic signals is best added as an insert at the mixing desk.
Not to mention feedback issues on stage. It gets pretty crazy fast (in a bad way).
John
Basic Audio Pedals
www.basicaudio.net/
wavley
Quote from: John Lyons on July 24, 2009, 12:30:03 AM
John
I agree with this.  A couple of days ago I was reading Mix magazine and there is an article about The Faint's live rig and they use a cheap Wal Mart distortion pedal as an insert because they actually like it better than the boutique pedal they accidentally lost.
Bone is in the fingers.
EccoHollow Art & Sound
eccohollow.bandcamp.com
Paul Marossy
John
+1
