High pass active filter questions
Started by Heemis, August 28, 2009, 12:29:53 PM
Heemis
So I've been looking for a way to set up a variable frequency active high pass filter.  If someone can confirm this, I would be eternally grateful.  I'm looking at this schem from the National Semiconductor op amp notes:
As per my thinking, if I switch the 110K resistors to a 100K dual gang pot, with 20K series resistors with each, that will give me variable resistance from 20K to 120K, which should result in a sweepable frequency from about 88 Hz to 530 Hz.  Am I correct in this assumption?
alanlan
Don't see why not although I haven't checked the actual frequencies
chi_boy
This conversation was along those lines.  You may be able to glean some information here:
http://www.diystompboxes.com/smfforum/index.php?topic=72601.0
"Great minds discuss ideas, average minds discuss events, small minds discuss people." — Admiral Hyman G. Rickover - 1900-1986
The Leftover PCB Page
Sacorus
Old topic here, but quick question.
When using a filter like this;
When using a single 9V supply(V- on op amp grounded), should the ground on the the filter be tied to Vbias instead of ground?
ashcat_lt
Sacorus
Cheers, good to clarify before i build  ;D
