SPST Switch Popping
Started by dpresley58, September 18, 2009, 10:41:04 AM
anchovie
But the way that diagram's drawn, if you make V1 and V2 the same source then you will be connecting + and - together!
dpresley58
...which is something I'm not wanting to do, I'm guessing.
I started looking through the datasheets for various JFETs after completely toasting a J201 by hitting it with the full 9v on the gate. A wisp of light grey smoke and "that smell" rewarded the approach...
From what I gather, even though they're a normally-open device, I still need to spec a part that allows enough current through the source-drain junction and can handle more than 9v on the gate. Is this correct? If it is, a J111 is looking like a good candidate. I'm thinking a voltage divider to feed the gate will also provide a path to ground in order to bleed off residual capacitance within the JFET.
Runnin' blind here, so input is appreciated.
Little time to do it right. Always time to do it over.
