Dr Boogey JFET trouble
Started by realizewhoitis, November 26, 2009, 12:21:35 AM
realizewhoitis
I am trying to bias my Jfets in my dr boogey down from 8.6v to 5.5 without the use of trimpots any advice?
Ripthorn
Are you using fixed resistors?  If so, try larger resistance values.
Exact science is not an exact science - Nikola Tesla in The Prestige
https://scientificguitarist.wixsite.com/home
ubersam
what i've done is to temporarily solder in a pot/trimpot to set the bias do the desired voltage, then unsolder the pot/trimpot, measure the resistance, then solder a equivalent fixed resistor value in its place. other than that, there are some calculations that can be done based on the particular device's Vp, Idss, etc. if you're interested in that, read up: http://www.runoffgroove.com/fetzervalve.html
realizewhoitis
Quote from: ubersam on November 26, 2009, 01:04:44 AM
when i measure the jfet do i measure drain to source or drain to ground?
ubersam
if you're referring to measuring the Vp and Idss of the JFET, here is what you'll need: http://www.runoffgroove.com/fetzervalve.html#11
anchovie
I'd go with trimpots. Far easier than teting a bunch of JFETs and you can tweak the circuit using the best measuring device of all - your ears!
bancika
I used pots to find the value and replaced them with fixed resistors. I used pin sockets to make them easy to swap.
jkokura
Quote from: bancika on November 26, 2009, 06:28:47 AM
I like how you placed the effect over a Mesa ad. Classy.
