black one to ground (if you've boxed this, an easy way to do it is to just stick the probe into a jack, assuming you've done the wiring right
red one touches the lead you wanna test
you'll wanna set your multimeter relatively low (20V should be fine) otherwise you'll be getting inaccurate readings
