|AMPAGE| |GEOFEX| |AMZ|
June 17, 2013, 09:40:20 PM
896199 Posts in 97958 Topics by 28941 Members
Latest Member: fusseltier
Home Help Login Register
DIYstompboxes.com  |  DIY Stompboxes  |  Building your own stompbox  |  [Tutorial] Making a Multicolor Etching! 0 Members and 1 Guest are viewing this topic. « previous next »
Pages: 1 [2] 3 4 5 6 7 Go Down Print
Author Topic: [Tutorial] Making a Multicolor Etching!  (Read 27692 times)
Slade
Fernando R. from Chile
WWW
Re: [Tutorial] Making a Multicolor Etching!
« Reply #20 on: December 17, 2009, 10:26:59 PM »
You're welcome! Glad you like it! Wink
Logged
markeebee
Mark B, UK
« Reply #21 on: December 18, 2009, 08:01:59 AM »
Thank you very much Fernando.  You are an artist, an engineer and a true gentleman!
Logged
KazooMan
The Third Time is the Charm
« Reply #22 on: December 18, 2009, 08:47:25 AM »
The third link worked just fine.  Very nice tutorial.  I need to work harder at masking off areas that don't get a good coating of toner.  The tips on sanding are also appreciated.  I have been using steel wool to prepare the surface and it doesn't always result in good adhesion of the toner.
Logged
Valoosj
Yorick
« Reply #23 on: December 18, 2009, 10:04:07 AM »
¡Muchas gracias Fernando! Y no te preocupas de tu Inglés Wink
Ahora estoy pensando de un dibujo como los tuyos para un 'swell pedal' (el de Solderman) y un woolly mammoth. Sólo para probar tu técnica.
Logged
Quote from: frequencycentral
You squeezed it into a 1590A - you insane fool!  icon_mrgreen
Quote from: Scruffie
Cap
Riccardo C. - Italy
« Reply #24 on: December 18, 2009, 11:02:29 AM »
Thanks for the tutorial!!!!  Grin Grin
now..i need new enclosures.. Cheesy
Logged
Kicking the sh!t of of your speakers since 2008
WWW
« Reply #25 on: December 18, 2009, 12:23:34 PM »
Thanks for the tutorial Fernando, I'm downloading it as we speak. I yearn to produce etches like yours, it's one of my goals for next year.  icon_cool
EDIT: OK, just read the whole tutorial, you attention to detail is excellent. Your etches are so good that my mouth is literally watering. My GF thinks I'm odd for that.
« Last Edit: December 18, 2009, 12:38:56 PM by frequencycentral » Logged
bancika
Branislav S.
WWW
« Reply #26 on: December 18, 2009, 12:39:50 PM »
So cool, thanks for the tutorial
Logged
The new version of DIY Layout Creator is out, check it out - http://diylc.org
Hupla
Colin S.
« Reply #27 on: December 18, 2009, 04:42:11 PM »
Hey guys. Just want an opinion. Is it easy to etch an enclosure after you have drilled holes into it? I can imagine it isn't too different, I just want to know as I don't think ill be able to etch for a while but I want to get the pedal done soone.
Logged
Completed builds: BSIAB2
Pedals to build: Dr.Boogey, TS-808
Slade
WWW
« Reply #28 on: December 18, 2009, 04:49:42 PM »
You're welcome, guys, I'm so glad you like the tutorial!  icon_biggrin
I think the sanding is a very important part of the process. Much people doing their first time etching don't pay attention to this part.
Valoosj, gracias por hablar en español! Eres nativo, aprendiste o usaste un diccionario? Haha.
Rick, just give it a try. It's so infinite as what you can design. Some persons think this techniques are limited... Maybe the colors are a limitation, but not the designs.. Just look at InsaneKane beautiful reverse-etchings... Because of that I incentivate you all to innovate applying your own ideas in the tutorial Wink
You can do it by protecting the holes (after the hard sanding work) with masking tape. The difference is that you won't immerse the enclosure on the etchant, but you shed the etchant over the designs in drops very carefully, just protect the areas around the designs and all the parts of the enclosure that don't have designs.
« Last Edit: December 18, 2009, 04:51:25 PM by Slade » Logged
Hupla
Colin S.
« Reply #29 on: December 18, 2009, 04:57:45 PM »
So it's not a good idea to immerse it in the etchant but you can still do it? im not familiar with the drip technique seems more awkward.
Logged
Valoosj
Yorick
« Reply #30 on: December 18, 2009, 05:00:03 PM »
Vivo en Bélgica, un pequeño país que nadie conoce y necesitamos aprender lenguas. ¿Porque quién habla néerlandes?
Estudio Inglés y Español en el instituto superior de Amberes, y hablo un poco de francés y allemán.
Logged
Slade
WWW
« Reply #31 on: December 18, 2009, 06:56:13 PM »
I don't recommend doing the immersion in this case, I recommend to shed the etchant over the designs carefully Wink.
Ok, estás escribiendo muy bien, falta escucharte hablar para evaluarte! Haha, sólo bromeo. Ni siquiera conocía el nombre de tu idioma, pero si he escuchado mucho de Bélgica Wink Yo intento dar a conocer Chile al mundo a través de mi trabajo, es una buena forma!
Logged
dave c. -Hammer Mtn. ON
« Reply #32 on: December 18, 2009, 08:08:41 PM »
Great job on the tutorial Fernando, thnaks for sharing!
dave
Logged
"Turn it up to 10 and rip off the knob."- Patterson Hood
Slade
WWW
« Reply #33 on: December 19, 2009, 10:48:07 AM »
You're welcome Wink
Thanks for your comment.
Logged
guitarman89
« Reply #34 on: December 19, 2009, 12:46:43 PM »
thanks for this tutorial! great work!
Logged
built: MXR Dist+,dod250-280,dr boogey,IC buffers,cmos drive,multiface,20W SS pwr amps,phase90,tubescreamer,rat,amzMB,wuly mammoth,dod280,zombie chorus
under constur:60W 3886 amp,jcm800 em
www.myspace.com/guitarmanbll
www.myspace.com/filospinatopunk
Hupla
Colin S.
« Reply #35 on: December 20, 2009, 09:42:16 AM »
So do ya let the etchant run over it or like let it puddle on the part you want to etch?
Logged
Slade
WWW
« Reply #36 on: December 20, 2009, 10:05:50 AM »
The second.
Just shed the etchant in drops over the designs until you cover them completely (You don't need to cover all the surface, just the designs, the surface must be protected with nail enamel and masking tape), then use a tip to remove the metal rests while the etchant is still working, like stirring it. Once the etchant is agglomerated just use a napskin to take off this rest, clean the enclosure with water and an old toothbrush and see if the etching is deep enough. Here I let you some pictures explaining this:
Logged
Hupla
Colin S.
« Reply #37 on: December 20, 2009, 10:14:48 AM »
The second.
Thanks very much. it makes alot of sense now.
Logged
Slade
WWW
« Reply #38 on: December 20, 2009, 02:25:45 PM »
You're welcome. I want to see the etchings you'll do in the future Wink
Logged
Hupla
Colin S.
« Reply #39 on: December 21, 2009, 12:14:48 PM »
I should have one in the next few weeks, and looks like i wont have to do the drip technique Smiley
Thanks so much for your tutorial.
Logged
Pages: 1 [2] 3 4 5 6 7 Go Up Print
« previous next »
Jump to:
