Splitter/Buffer into computer then out
Started by El Heisenberg, January 02, 2010, 01:21:36 AM
El Heisenberg
Im doin this:
http://www.diystompboxes.com/smfforum/index.php?topic=74979.0
Its basically a keyboard in a box to control the ambiloop program to use it as a looper. I need to build something to split the signal after my pedal chain, buffer it into my computers mic input which is all I can plug it into, and then if needed, something to buffer it when it comes out of the computer. Then, I gotta combine the signals to play it out of one amp.
I was thinking the splitter-blend from run off grooove, but both signals would be quiter when blended wouldn't they?
Someone in the thread said I need a 5k resistor to ground at the input of the computer. I was gunna add this to the splitter blend.
Any better ideas?
"Your meth is good, Jesse. As good as mine."
El Heisenberg
El Heisenberg
blah im just gunna build it rite now and see what anyone says later
