K...You Asked For It...
Started by petemoore, September 28, 2003, 12:06:01 AM
Somebody was aaskin bout the Mega Crunch Stompbox...Like Ultra [new metal?] Heavy Dual Rect type 'Mashive' Overload...
 Here it is...[the closest thing I've gotten to that so far:
 EH LPB With Very small incap [mine has parallel socket for adding a cap/cap value to the input. Vol set about 3/4
 Shredmaster Gain Up,> Bass/treble ~3/4> Contour Clockwise> [Thin Scoop] and vol ~2/3
 Sili Face II...4401's [the way it's setup there's very little gain by itself]
 I just built the Sili Face II tonight...it was boosting, and thickening mostly and distorting some with hard atacks on chords...working well with other boosters etc... Then I tried this combo...
 The deeply resonant well defined bass sounds uniquely 'different' than the treble, which is a smooth slice.
 I'm sure it doesn't have the same versatility as a DR type tube amp, but it's quite the metal mashing machine, and gets to a dynamic nasty zone
that I was instantly endeared with, and fascinated by...definitely worth a try...actually any one of the three is cool havin around...do I see a box with 2-3 switches on it?
