Pinnacle problem
Started by iqvalue, January 22, 2010, 04:07:02 PM
itzalak2
You re right! it has considered as 1m. Changing to 1 MEG works and amplifies!
Will check tomorrow the circuit again. Thanks for all to everybody.
samhay
itzalak2
Hi,
I found the problem!, it was a bad solder only!. Thanks to all for all your help.
1 Thing I see is that the gain pot acts like a limiter of distortion volume bat does not reduce gain. Is this normal?
Regards.
You *need* the upper cap to get gain. Otherwise the lower FET drives the upper FET for gain essentially unity.
Yes, many sims take "m" or "M" as milli. I have to type "Meg" to get a meg. If in doubt, type "1000K".
BTW: your sim shows "4.50e3A" battery current. This is 4,500 Amps!! More than a dozen of my tractor's starter-motors! This also suggests your sim is taking "1M" as "milli". (9V over 2milli-Ohm is 4,500 Amps.)
itzalak2
But is it usual the gain pot behavior? It works like a volume limiter of gain but doesn't' remove add distortion.
The signal is already distorted *before* it gets to that pot. Can't change flavor, only total amount.
