Standoffs on PCB
Started by MullisMan, February 27, 2010, 12:33:07 PM
MullisMan
I'm going to be using the plastic standoffs that can be purchased from Small Bear to mount my PCB to my enclosure.  I'm using the Eagle CAD software and the gaussmarkov libraries for my parts.  I don't see anywhere in the library to place a hole in the board for these standoffs.  How do I put a hole large enough in the board to make room for the standoff and what is the diameter of the standoff?
With the fire in my bones.
potul
There is a library in the default eagle package called "holes". You have there several different hole diameters.
MullisMan
Ok cool I found that, however I'm looking on Mouser for the datasheet and it's pretty unclear on the diameter of the standoff.  I don't know how big of a hole to put in the PCB.  I'm using the standoffs with part # 561-LAD187 on Mouser.
.Mike
Check out the datasheet...
"Fits Recommended Hole Size of .156 - Panel Thickness 1/16˝"
Mike
If you're not doing it for yourself, it's not DIY. ;)
My effects site: Just one more build... | My website: America's Debate.
MullisMan
I did see that, however it labeled that column as length above, so I was a little confused.  That's going to make my PCB hole about 4 mm, and that looks absolutely huge on my PCB design in Eagle.  Time to move some parts around....
Thanks for the help!
