Tightening Plastic DC Jacks
Started by sixstringphil, March 01, 2010, 08:12:20 PM
sixstringphil
How do you guys get your plastic DC jacks tight? They are the only thing I have problems with coming loose. I can't seem to get a good enough grip on the jack while I turn the nut. Any tips for that?
joegagan
which type are you talking about?
internal or external nut?
bumblebee
I just use my fingers, seems to be tight enough. If you use a tool they can crack if you over do it.
Finger tight is right IMO.
StereoKills
I usually finger tighten them and then gently use a small wrench to finish it while pressing hard on the other end, let friction do the work for you!
"Sometimes it takes a thousand notes to make one sound"
Paul Marossy
I use a crescent wrench for the type with an external metal nut or a 9/16" box end wrench for the type with an internal plastic nut.
 Glue, some fine stuff.
Clothespins on jacknut, jackbody pinned with a precision-angle cut popsicle stick, glue inundating all possible surfaces within the glue span area, and not outside it is the tricky part.
Paul Marossy
Quote from: petemoore on March 01, 2010, 09:24:06 PM
Huh?  ???
John Lyons
Quote from: StereoKills on March 01, 2010, 08:44:30 PM
+1
I use a socket but just finger tight.
I press my thumb on the outside to keep it from
rotating until it gets friction tight.
Basic Audio Pedals
www.basicaudio.net/
