|AMPAGE| |GEOFEX| |AMZ|
September 08, 2010, 05:10:53 AM
706516 Posts in 81765 Topics by 18867 Members
Latest Member: somorastik
Home Help Login Register
DIYstompboxes.com  |  DIY Stompboxes  |  Building your own stompbox  |  Capacitance on 1k Fuzz Pot 0 Members and 1 Guest are viewing this topic. « previous next »
Pages: [1] Go Down Print
Author Topic: Capacitance on 1k Fuzz Pot  (Read 360 times)
dogtone
« on: March 09, 2010, 07:11:31 AM »
Hi Folks
I have been reading stuff here since the Fuzz Bug bit me. Cool stuff what a couple of transistors and a few caps and resistors can do.
I spent most of last weekend figuring out how I could screw up such a simple circuit.
After rebuilding the whole thing, an easyface type fuzz with a 1k fuzzpot and an external bias pot, I come to find out the 1k fuzz pot is acting more like a variable capacitor than a resistor Huh.
I check another one, both alpha pots with a  code of8A4 on the back, same deal.
So I  replace the 1k pot with another alpha pot with a different code and it works!
Any one else have this problem with pots?
Logged
cpm
Carlos P [spain]
Re: Capacitance on 1k Fuzz Pot
« Reply #1 on: March 09, 2010, 10:24:08 AM »
how is that? can you tell more details?
Logged
joegagan
« Reply #2 on: March 09, 2010, 10:41:36 AM »
when you say easyface type, that implies there would not be a fuzz pot. if you wired the fuzzpot like a normal fuzzface, it actually does act like a capacitor control, the 22uf to ground is being varied by the fuzz pot.
Logged
insert doug h or eric h quip here
dogtone
« Reply #3 on: March 09, 2010, 03:12:12 PM »
The thing is I get the capacitance reading with the pot out of the circuit. That's the perplexing thing.
I removed it and put in a new one and the pedal works great.
Before I replaced the pot I couldn't get a steady 4.5 volts on the collector of Q2.
Joe,
doesn't the 1k fuzz pot I put in vary the bias in the easy face like it does in the ff and the 100k pot act like a tone control by mixing the input caps?
Logged
dogtone
« Reply #4 on: March 09, 2010, 04:16:03 PM »
Here's a picture of the board of my not an easy face fuzz
Thanks Again for your comments
« Last Edit: March 09, 2010, 04:34:50 PM by dogtone » Logged
joegagan
« Reply #5 on: March 09, 2010, 07:15:08 PM »
interesting, nice picture. looks like you have a silicon at q2 and ge at q1. did you try it the other way around ( the way i usually like it )?
sounds like you found the problem, a messed up pot.
my fave combo for easyface is 2k/47 uf to ground at q2(ge)emitter, 25 k trim to set bias @ q2, 250k input gain control pot, no fuzzpot, maybe even a 75k feedback resistor in place of the 100k.
if the tranny is good on q2, it sounds pretty nice.
Logged
dogtone
« Reply #6 on: March 10, 2010, 06:08:55 AM »
Cool suggestions
Right now I really like the smooth sustain with the ge in Q1 and the hi gain si in Q2. I will have to take another listen to the si in Q1 and the ge in Q2
I am going to try a 2k fuzz pot and see how it sounds.
Thanks Again
Logged
Pages: [1] Go Up Print
« previous next »
Jump to:
