gated Fuzz face prob
Started by philbinator1, April 14, 2010, 09:51:12 PM
philbinator1
Hi guys,
I'm making another Fuzz Face for a friend, which i thought would be pretty simple.  But, after populating the vero
I put it on my breadboard to test and i'm getting a really stong gated sound...only sounds if I hit the strings hard.  Really nasty.
Here are the trannie voltages:
Q1   E: Zero volts
       B: 0.653V
       C: 1.324V
Q2   E: 0.8V
       B: 1.328V
       C: 8.48V
Battery: 8.5V
There are no mods, with the exception of a 10K trimpot where R3 was, so I can bias.  When I adjust the trimmer the voltage
only goes down from 8.48V to 8.44V or something like that.  Am i right in saying the collector of Q2 is way too high?  should it be around 4.5?
I have double checked my vero layout and it appears as it should be, no solder bridges either.  Maybe I should re-solder?
oh and i'm using a 100K-B for the volume and 1MB for the fuzz pots.
Cheers,
Phil   :)
"Hows are we's?  We's in the f*cking middle of a dinners meal!  Dats hows we am!" - Skwisgaar Skwigelf
rousejeremy
I'm willing to bet your fuzz pot is the problem. 1 Meg is HUGE! I made a fuzz on the breadboard that was sweet sounding with a 1K fuzz pot, and gated with a 2K. Amazing how much of a difference a little change can make.
Use this link http://www.diystompboxes.com/analogalchemy/emh/emh.html when building fuzz faces, it'll save a lot of stress.
Consistency is a worthy adversary
www.jeremyrouse.weebly.com
philbinator1
Quote from: rousejeremy on April 14, 2010, 09:55:26 PM
:D  D'oh!  I used 1M instead of 1K!  Haha!  Thanks man I'll do a switcharooney and see if it works.   :icon_mrgreen:
philbinator1
I tried it and to some degree it worked, but i'm still getting a high reading (around 7.5V) on the collector of Q2.   :icon_question:
rousejeremy
What trannies and what layout are you using?
philbinator1
heres the layout:    http://i809.photobucket.com/albums/zz13/philbinator1/Fuzzfacesilicon.gif
i'm using 2N3904's, just like i did with my last fuzz, and they seem to be fine.
jrod
Have you double checked the values of the other components? Your voltages are way off. The Q1 collector voltage should be about .5V and Q2 about 4.5V. I suggest checking to make sure all the resistor values are ok.
philbinator1
Quote from: jrod on April 16, 2010, 10:09:30 AM
thanks mate, willdo!   :)
mac
Q1 values are ok as silicons bias higher then germs.
Q2 collector resistors should be together 6k or so for typical 2n3904.
mac
smallbearelec
This article:
http://www.smallbearelec.com/HowTos/Breadboarding/Breadboard.htm
has some useful poop on lining up and tweaking a silicon FF. IMO 2N3904 is not best choice for either device in this pedal, and especially for Q1. Gain is usually too high to bias easily.
Regards
SD
joegagan
joegagan
Quote from: smallbearelec on April 16, 2010, 07:02:29 PM
This article:
Regards
SD
steve, i had not seen that article before. very well done. should be required reading for newbies!
philbinator1
Well put!  I'm printing that off now, will read soon.  I fear breadboarding, but will look into it.  Need...learn...more...   :)
