Polyphase debug / diy thread
Started by chicago_mike, April 22, 2010, 09:46:12 PM
chicago_mike
Hey all. Thanks to everybody here and elsewhere my other builds are good! :D
Now its onto this goofy thing. The Topopicone(sp) polyphase. I etched the revision board and populated it a year or so ago and have finally gotten around to testing it.
Issue 1. On my scope...before I power it up I get signal to pin 3 of IC1. Cool. After I power it up..the reading goes way off my scope. as with all other 4558's. However..my output signal, is there..its larger, meaning louder than the input signal.
Issue 2, I think I have a dead 4558. the upper left IC just under the .33uf cap. I get voltages but with my audio probe I get no sound out of pins 2-7. I clicking ish sounds when I touch the IC pins with my audio probe and my scope in that area does the same thing as with my other IC's. The reading jumps way high off the screen of my scope.
I adjusted the trimpot for 6.70 volts. My vactrols are getting around 5.5 volts off the LDR side.
B+ is 13.53 ( I know its not B+ but F$$k it! :icon_razz: ) and Vref is around 6.5 and 5.5 depending on the IC(4558) havent yet taken figures off the 4013.
Ill get more readings up real soon, just wondering who else has built one and what problems arose. Im using VTL5C4/2's since those are the only ones I have. But building my own is not an issue, I just need to know the light and dark resistantces.
Thanks for any and all help. and..lastly...why cant I see what I am typing after the message gets underneath the window?? it jumps around...odd..
chicago_mike
OKAY...
It goes up, but then kind stays there. Its also SUPER microphonic. The depth control pot and wire, the middle wire is VERY microphonic.
And if I move it or the pot, the sound goes to pure sign wave or screachy LOUD as hell microphinic feedback noise.
Bad, but I can get this.
Just need some insight.
chicago_mike
My CA3140 gets hot! .......Weird! :-[
chicago_mike
Voltages of IC's in POLYPHASE
1 FIRST 4558
1   7.51
2   7.55
3   6.15
4   0.00
5   5.56
6   6.59
7   7.55
8   14.73
IC2  1458
No ic in socket at reading only have a couple and didnt want to blow them.
1   2.38
2   6.78
3   2.90
4   0.00
5   6.79
6   0.00
7   0.00
8   13.07
IC 3 4558 (underneath IC1)
1   7.70
2   7.57
3   6.12
4   0.00
5   6.05
6   7.63
7   7.64
8   14.66
IC 4 Just underneath IC 3 RC 4558
1   7.63
2   7.65
3   6.11
4   0.00
5   6.05
6   7.71
7   7.68
8   14.67
IC 4  ( Bottom IC ) RC4558
1   7.56
2   7.52
3   6.31
4   0.00
5   6.31
6   7.52
7   7.48
8   5.96  bad???
IC 5 Middle IC BA 4558
1   7.55
2   7.54
3   6.40
4   0.00
5   6.59
6   7.50
7   7.46
8   14.70
IC 6  CD4013
1   14.67
2   14.67
3   0.00
4   9.52
5   0.00
6   13.34
7   0.00
8   0.00
9   0.00
10   0.00
11   0.00
12   14.67
13   0.00
14   14.67
IC 7 CA3140  THIS IC GOT HOT, SO READINGS ARE WITHOUT IC IN SOCKET HOT TO THE TOUCH!
1   0.00
2   0.00
3   7.18
4   0.00
5   0.00
6   0.00
7   14.68
8   0.00
IC 8 LM324 TI CHIP
1   6.80
2   7.32
3   6.80
4   14.69
5   6.79
6   7.50
7   6.77
8   6.88
9   7.52
10   6.77
11   0.00
12   6.75
13   6.88
14   7.38
14.71     volts  to the first vactrol and I assume the same to the others. But I think they are in backwards????
soohyun2222
#4
Hi y'all, I am still working on the polyphase, which was uploaded by P. Nelson in 2006. Is anybody working on this project still?
here are my voltage readings:
The voltages in the bracket are the voltage readings by chicago_mike.
EH polyphase Voltages
Power supply   18.43V
15V regulator   14.77V
IC   1458
pin   1:   2.03 average V   [2.38]   *
pin   2:   6.70V   [6.78]
pin   3:   6.48 average V   [2.9]   *
pin   4:   0V   [0 ]
pin   5:   6.70V   [6.79]
pin   6:   6.71V   [0 ]
pin   7:   6.48 average (max:12.48V, min: 0V) V   [0 ]
pin   8:   13.04V   [13.07]
IC   4558(1st from top)
pin   1:   7.25V   [7.51]
pin   2:   7.23V   [7.55]
pin   3:   7.07V   [6.15]   *
pin   4:   0V   [0 ]
pin   5:   6.99V   [5.56]   *
pin   6:   7.25V   [6.59]   *
pin   7:   7.24V   [7.55]
pin   8:   14.36V   [14.73]
IC   4558   (2nd from top)
pin   1:   7.21V   [7.70]
pin   2:   7.21V   [7.57]
pin   3:   7.14V   [6.12]   *
pin   4:   0.001V   [0.00]
pin   5:   7.08V   [6.05]   *
pin   6:   7.23V   [7.63]
pin   7:   7.23V   [7.64]
pin   8:   14.34V   [14.66]
IC   4558   (3rd from top)
pin   1:   12.80V   [7.63]   *
pin   2:   7.25V   [7.65]
pin   3:   7.10V   [6.11]
pin   4:   0V   [0 ]
pin   5:   7.14V   [6.05]   *
pin   6:   9.01V   [7.71]   *
pin   7:   1.440V   [7.68]   *
pin   8:   14.31V   [14.67]
IC   4558   (4th from top)
pin   1:   13.50V   [7.55]   *
pin   2:   10.36V   [7.54]   *
pin   3:   0.800V   [6.4]   *
pin   4:   0V   [0 ]
pin   5:   7.09V   [6.59]
pin   6:   7.48V   [7.5]
pin   7:   1.488V   [7.46]   *
pin   8:   14.31V   [14.7]
IC   4558   (5th from top)
pin   1:   12.98V   [7.56]   *
pin   2:   7.24V   [7.52]
pin   3:   7.10V   [6.31]
pin   4:   0V   [0 ]
pin   5:   7.10V   [6.31]
pin   6:   7.26V   [7.52]
pin   7:   1.518V   [7.48]   *
pin   8:   14.31V   [5.96  bad??? Y]
IC 6  CD4013
pin   1:   14.13V   [14.67]
pin   2:   14.13V   [14.67]
pin   3:   0V   [0 ]
pin   4:   14.13V   [9.52]  *
pin   5:   0V   [0 ]
pin   6:   14.13V   [13.34]
pin   7:   0V   [0 ]
pin   8:   0V   [0 ]
pin   9:   0V   [0 ]
pin   10:   0V   [0.00]
pin   11:   0V   [0.00]
pin   12:   14.13V    [14.67]
pin   13:   0.004V   [0.00]
pin   14:   14.13V   [14.67]
I realized that the readings change with the 2PDT switch. Here are the readings: switch option 1/ switch option 2
pin   1:   1.222V/?   [0 ]  *
pin   2:   11.97V/?   [0 ]  *
pin   3:   13.89V/?   [7.18]  *
pin   4:   0V   [0 ]
pin   5:   0V   [0 ]
pin   6:   11.98V/ 6.77V   [0 ]
pin   7:   14.13V/?   [14.68]
pin   8:   13.40V/ 8.10V   [0 ]
IC 8 LM324 TI CHIP
pin   1:   6.71V   [6.8]
pin   2:   6.96V   [7.32]
pin   3:   6.71V   [6.8]
pin   4:   14.27V   [14.69]
pin   5:   6.69V   [6.79]
pin   6:   6.81V   [7.5]
pin   7:   6.69V   [6.77]
pin   8:   6.70V   [6.88]
pin   9:   7.85V   [7.52]
pin   10:   6.70V   [6.77]
pin   11:   6.70V   [0.00]   *
pin   12:   6.68V   [6.75]
pin   13:   6.70V   [6.88]
pin   14:   6.70V   [7.38]
I would certainly appreciate your comments, thank you.
