Rubber pot covers?
Started by Taylor, May 05, 2010, 06:02:07 PM
Taylor
I often orient my board-mounted pots on the solder side of the board, such that the back of the pot will short out the soldered connections if I don't put something there to stop it. I've used cardstock to keep them from shorting, but I'd like to do something a little better. I have once seen rubber covers that slip on the back of a pot, seemingly for this very purpose. Unfortunately I don't remember where I saw this and some Googling didn't turn anything up.
Anyone know what those might be called/where to get them/another solution?
Brymus
Nice one Rick,the guy that made those is a bit of a Jeri Ryan fan eh?
Me too!
theehman
I use low profile rubber feet, one on the back of each pot.
Ron Neely II
fx schematics and repairs
Taylor
#4
Quote from: frequencycentral on May 05, 2010, 06:05:53 PM
http://www.buildyourownclone.com/board/viewtopic.php?f=9&t=20231&start=0&st=0&sk=t&sd=a&hilit=pot+condoms
Cool, but too fiddly for me. As an American, I require a readymade, pre-packaged solution.  :icon_twisted:
Quote from: theehman on May 05, 2010, 06:23:31 PM
Do you have a link? That would work well but the ones I have are too thick.
Brymus
Home Depot and Lowes sell them for putting on the bottom of chair legs to keep from scratching the floor.
Almost the exact size as a 24mm pot,About 4$ for a package 20 IIRC
Taylor
I thought about those finger cots when looking at the BYOC thread, but I'd prefer for my pedals not to have that gross condom smell.  :icon_confused:
Edit: are your last 2 posts meant to be used in combination?
Brymus
Quote from: Taylor on May 05, 2010, 06:46:11 PM
Wouldnt that be a Heavenly Voyage  :icon_lol:
Taylor
Hmm, not bad. But don't they need to be shrunk onto the pot to stay on?
Spidermonkey
Nope, I'm pretty sure those are preshrunk. I've made a couple, and they stay on the pots VERY well.
Steve Mavronis
Quote from: Brymus on May 05, 2010, 06:38:01 PM
Do they have this the size of a 16mm pot?
Guitar > Neo-Classic 741 Overdrive > Boss NS2 Noise Suppressor > DOD BiFET Boost 410 > VHT Special 6 Ultra Combo Amp Input > Amp Send > MXR Carbon Copy Analog Delay > Boss RC3 Loop Station > Amp Return
zombiwoof
I've seen those black plastic pot covers that come on the "Blacktop" wah pots for sale separately somewhere, but I don't remember where.  They'll only fit the 24mm pots, though.
Al
theehman
You could also use a square of double-sided foam tape.  Just leave the protective backing in place so the board doesn't stick to it.
Ron Neely II
zombiwoof
Found it at Banzai:
http://www.banzaimusic.com/Dust-Seal-Cover.html
I think I saw them at a U.S. store, too, but don't recall which one.
Al
.Mike
Quote from: zombiwoof on May 07, 2010, 03:53:17 PM
Found it at Banzai:
That made me think of the clear plastic tubes used to store documents and such. I figured there has to be a company that sells just the endcaps. A search turns up this: http://www.stockcap.com/store/Product/SkuInfo.aspx?id=1092
It looks like it would possibly fit 16mm pots, and costs about a dime apiece if you buy 500. Taylor, maybe you should take a look, measure your pots, and order a few samples?
Another thought is something like Plasti Dip.
Mike
If you're not doing it for yourself, it's not DIY. ;)
My effects site: Just one more build... | My website: America's Debate.
Taylor
Quote from: .Mike on May 07, 2010, 04:10:00 PM
Found it at Banzai:
Mike
Wow, excellent find Mike. That looks like it will fit perfectly on 16mm pots. I think I just might nab those. Thanks!
I bet the wah pot covers are just those same things, sold at a premium because of the special use. The wah "tension clutch" is just a plastic cable clamp you can get at any hardware store, for example.
Steve Mavronis
The inside length is 1/2" and the body of 16mm pots are not that thick.
