Can we start a Demo Video Thread?
Started by mikemaddux, May 17, 2010, 03:33:11 AM
thermionix
Quote from: Ben Lyman on April 08, 2016, 01:42:20 PM
Tone Bender with vintage 1966/7 PNP Ge transistors
Reissue 5F1 Champs?
Ben Lyman
Quote from: thermionix on April 08, 2016, 03:36:58 PM
Reissue 5F1 Champs?
Close! Matching Lil' Dawg 5F2A "Prince" amps by Jim Nickelson with 12" Weber Alnicos in narrow panel tweeds by Peter Mather
"I like distortion and I like delay. There... I said it!"
        -S. Vai
Ben Lyman
Ring mod fuzz octave. Still don't know what to call this one
        -S. Vai
sounds great man....nice octaves, loads of sustain, cool... 8)
Great Ben. Love the colour.
Me thinks you have one too many of those amps. The other would sound great in my little room.
Ben Lyman
Here's the VTF MKII Germanium Supafuzz/Tone Bender with variable input cap ala deluxe bazz fuss and treble bleed on the fuzz pot to retain some clarity at low gain settings.
        -S. Vai
Ben Lyman
The Super Cod OD/distortion. It's sort of a VLOD and OCD but a lot of values changed and using one Ge and one Si diode for clipping.
        -S. Vai
gtudoran
A new full-tube/high voltage overdrive pedal that i'm working on.
- Features Gain / Bass / Treble and Volume controls (James style tone-stack) along with a switch for choosing between scoop and hump mids.
- The 2nd foot-switch will be wired so you can change the mid freq. response.
- The pedal is very dynamic and responds excellent to the picking strength, also very responsive to guitar volume change.
- The tone is a little bit top-end oriented with a little bit of fuzziness on the top (more like a fender amp that is driven hard).
- Anode voltage 260V / 3 gain stages and one cathode follower directly into the tone-stack.
storyboardist
Finished editing this last night and thought I'd share. Demo of the Valve Wizard Equinox II
Rig: Gibson SG Jr > Equinox II > Vox AC4C1
darron
this one's in stereo. so... i dunno? earphones?
Benoi31
An old build: Aion Electronics Phobos (Tonebender MkIII)
I did this quick recording:
I really like it in front of an overdrive amp, it is between a Fuzz Face and a Big Muff.... Except it can work with Orange amps!
steveyraff
King Of Clone with dual externalised diode switches on each side. High Gain mod added to right side. Internal presence trimmers:
Bluesbreaker and TS808 with diode switch for dual red LED's:
Steve.
www.outlandstudios.co.uk
roseblood11
Quote from: tasos on November 16, 2015, 09:41:20 AM
I recently recorded a single-riff video of a Real McTube using 6n2p tube!
Had no electric laying around so i played my acoustic guitar  ;)
Enjoy!
Which hammertone color did you use hear? Looks better than the Hammerite Blue!
davidh
#634
Hi everybody!
Old thread, but I thought I like to show my latest projects here since it is a video demo thread. I am new to the forum and i hope it is cool to post this stuff here...
I'm still working on this stuff, it is work in progress, so questions, comments and suggestions are welcome :)
Here it is:
1) This is a basic PT2399 delay. The Time is controlled by a 10 Step sequencer (CD4017 circuit). It can go from weird pitch shifting to subtle chorusish sounds.
2) Here's a ducking effect. It is done like that: The "Bassdrum" (coming from the boss loopstation) goes into the envelope follower (based on the mu-tron follower section) the envelope signal controls the VCA which squashes the guitar signal. The VCA is done with the Coolaudio V2164 chip using only one channel.
In the video you see these boxes from left to right: loopstation as the bassdrum source - envelope follower - one LFO - a second LFO - VCA (on breadboard) - to the far right you see a simple true bypass switch to bypass the VCA.
3)
Again the VCA, but now it is controlled by the first LFO, so it's a tremolo. The second LFO can change the speed of the first one, so it is alternating between two pre-set speeds. Then also the envelope follower can control the first LFO. Every time the bassedrum is hitting, the tremolo starts from a fast to a slow rate.
I am working on some kind of modular guitar effect setup. The idea is to use some VCA's, LFO's, Delays and envelope followers that that can interact with each other. You can combine them in different ways to to create different effects.
So what do you think? I'm open to questions and suggestions...
Cheers!
David
my latest project..... i had so many options on breadboard that i decided to include  all of them. :icon_mrgreen:
nice to have an overdrive for a change.....i still love my full on metal though..best of both worlds :icon_twisted:
wow nobody uses this thread for demo's anymore, shame......oh well here goes..
my latest little project..a 1590b reverb..true bypass.
TIMESTREAM REVERB.
rutabaga bob
Another nice one, Rob!  You always do such great work!
"I can't resist a filter" - Kipper
Cheers larry.   Yeah i needed a true bypass verb
For my bench setup with delay etc.  Had some tips from uncle samhay with it. Cheers man.
Came out great..well happy 8)
