|AMPAGE| |GEOFEX| |AMZ|
September 02, 2010, 11:12:36 AM
705369 Posts in 81672 Topics by 18802 Members
Latest Member: dener
Home Help Login Register
DIYstompboxes.com  |  DIY Stompboxes  |  Building your own stompbox  |  "Sonic Death Ray" Phaser - a phase insurrection! 0 Members and 1 Guest are viewing this topic. « previous next »
Pages: 1 2 3 [4] Go Down Print
Author Topic: "Sonic Death Ray" Phaser - a phase insurrection!  (Read 3482 times)
doc_drop
WWW
Re: "Sonic Death Ray" Phaser - a phase insurrection!
« Reply #60 on: July 29, 2010, 10:52:55 AM »
So, I was told this thing goes, "Swwwwwwwwwoooooooooooooooooooosssssssssssssssssshhhhhhhhhhhhhhh! "
But, it sounds more like "WooooooowWoooooooooooooowWoooooow" to me. What's up with that? icon_twisted
Rick, I know the ROG Tri-Vibe has a sweet sine wave shaped LFO. Maybe you should look at that one?
I am definitely going to build one of these. It is too sexy not to!
Logged
Ian M. - England
« Reply #61 on: July 29, 2010, 11:12:45 AM »
That sounds great, I like the flangerish ringing in the first clip, almost like it's on the verge of self oscillating.
Logged
igerup
Ulrik, Malmö, Sweden
« Reply #62 on: July 29, 2010, 03:30:39 PM »
wow, that sounds cool and far out.
Logged
Rick, a.k.a Perfboard Overlord
WWW
« Reply #63 on: July 31, 2010, 06:46:52 AM »
I had another idea about how to implement parity modulation. What if we add a single phase stage in the regen path, not fixed, but modulated by a single FET driven by it's own LFO? That way the regen signal would get flipped over between in phase and out of phase thus creating parity modulation?
Logged
Murder One
¿Por qué un baño de Slade tiene un grifo en cada extremo? ¡Para mantener el cloruro férrico parejo!
earthtonesaudio
Alex S.
WWW
« Reply #64 on: July 31, 2010, 06:57:49 AM »
Implementing that as a phase shift stage would be interesting; because the "polarity" would be frequency dependent.  An alternative idea, somewhere between this and the LED/LDR method posted eariler, would be to modulate a JFET instead of the switch in a polarity reverser type circuit.
Logged
the way they left us all in the dark, they buried the sun so I carry the torch
WWW
« Reply #65 on: August 05, 2010, 08:20:53 AM »
Parity modulation LFO redesigned, perf'ed and tested, home-made vactrols rolled. And the main PCB arrived today from my PCB man.....
......and some perf-porn for Slade:
« Last Edit: August 05, 2010, 08:56:03 AM by frequencycentral » Logged
Murder One
WWW
« Reply #66 on: August 05, 2010, 05:48:33 PM »
Here's the new parity mod circuit and layout. A little more graduated than the previous version. Incidentally, this circuit can also be used to replace pretty much any pot configured as a voltage divider, though you might want to limit the dark resistance of the LDRs by using resistors in parallel. Imagine - LFO control of BM tonestack, or of mixing between two signals, or..........
Logged
Murder One
WWW
« Reply #67 on: August 12, 2010, 08:08:43 AM »
PCB layout verified! Just hooked it up! This thing sounds awesome - even quieter than on breadboard. I can't wait to get it boxed up now......
Logged
Murder One
WWW
« Reply #68 on: August 12, 2010, 10:23:39 AM »
The more observant amongst you will have noticed that the FETs are having sex. This is the secret of good phasing IMO.
Logged
Murder One
Slade
Fernando R. from Chile
WWW
« Reply #69 on: August 12, 2010, 10:24:04 AM »
Fet-sex, ha?! You vouyerist cyborg!
Logged
Brymus
Bryan G. - Somewhere in the Mohave Desert USA
« Reply #70 on: August 12, 2010, 12:13:51 PM »
Not just sex.
It looks like a full blown orgy  Grin
Are you sure El H didnt do that layout ?  icon_twisted  icon_wink
Logged
Shame on you for only bothering to read it once. Don't come back until you've read it the other 99 times.     I'm so clever I might only have to read it 50 times........- Rick Holt
WWW
« Reply #71 on: August 13, 2010, 07:29:14 AM »
This is how I am proposing to implement the (quite complex) regen options:
The two regen inputs are on the left, one stage apart. The DPDT selects either parity modulation (from the parity modulation board) or fixed odd/even parity (selected by the SPDT). Then the regen pot and limiting resistor. Finally the 6 regen taps (each two stages apart) selected by the 1P6T rotary switch.
« Last Edit: August 13, 2010, 07:37:05 AM by frequencycentral » Logged
Murder One
Slade
WWW
« Reply #72 on: August 13, 2010, 11:29:35 AM »
Hey, why don't you make the switch to select manual parity or parity modulation into a 3pdt stomp?
Would be nice to have that option while you're playing Wink
Logged
WWW
« Reply #73 on: August 13, 2010, 11:32:21 AM »
Wow what a good idea, how could I not have thought of that?  Roll Eyes
Logged
Murder One
Slade
WWW
« Reply #74 on: August 13, 2010, 11:40:19 PM »
Because it's a young'n idea.
Logged
Pages: 1 2 3 [4] Go Up Print
« previous next »
Jump to:
