Simple MIDI splitter
Started by HeaD, June 27, 2010, 04:38:37 PM
HeaD
Hi guys, I want to build a simple MIDI splitter to connect two slave devices to my PC in order to synchronize them via MIDI clock:
Do you have a project to do that? ... and do that needs sort of power supplied buffer?
Sorry for my english :|
Processaurus
You know?  I bet you could just make a passive Y splitter cable.  Look at the beginning of the midi in on the diagram, the midi in port is just the LED side of an opto-isolator.  The driver circuit from the upstream device can probably drive two LEDs (one in each downstream device) in parallel without ill effect.
Processaurus
Doing the math, it looks as if running two devices' input LEDs will draw 6.5mA, which a cmos inverter can sink.
HeaD
Quote from: Processaurus on June 27, 2010, 07:46:41 PM
Would be amazing... are you sure that there is not an excessive loss of signal? Thanks.
FiveseveN
There shouldn't be a need for a MIDI splitter. MIDI devices almost always have a MIDI out/through port. But if they don't here are a couple of examples of pass-throughs: https://ccrma.stanford.edu/~gary/controllers/midi.html http://www.instructables.com/image/FXY7LDRF6S8S2BV/Creating-a-MIDI-thru.jpg
Processaurus
Oh yeah, or use the midi thru :icon_redface:.  I bet the Y cable thing would work fine too though.
