Simple "DEPTH" control for JKowalski's PIC12F683_TT_VCLFO_(B)???
Started by 3080, June 28, 2010, 01:50:39 PM
.Mike
Well, you could just use the full TapLFO, which has control for depth (called level). It's a 14-pin DIP instead of 8-pin. Any features you don't want can be set to a fixed value using a couple of resistors as a voltage divider. For example, if you didn't want wave distort, you could use two 5k resistors to set Pin 9 at 2.5V.
Alternatively, you could try something like this: http://www.diystompboxes.com/smfforum/index.php?topic=79446.0
Good luck!
Mike
If you're not doing it for yourself, it's not DIY. ;)
My effects site: Just one more build... | My website: America's Debate.
3080
I know electricdruid's TAPLFO....
... but I will try this:
A pot wired paralell with the LDR.
