Noob schematic reading questions
Started by itchyfingers, July 13, 2010, 07:43:13 PM
itchyfingers
Ok, I've built a few kits from BYOC and GGG, now just started trying to build some simple projects from schematics and had a couple of questions I was hoping you guys could help with...
Pots - I get that a resistor symbol with an arrow pointing at it is referencing a potentiometer, but how do I know if the pot should be linear or audio from the schematic?
Trannies - I get the difference between NPN and PNP symbols but how do you know which leg is the emitter, collector, and base from the schematic?
IC's - I can tell a triangle symbol is for an IC, but which pin is pin 1 on the actual IC (is it the one to the left of the notch?), and then how do they get numbered from there?
I'm sure I'll have more, but these are the big ones for me right now!  :icon_lol:
phector2004
1. Often, it will write A or B after the resistance. A = "Audio" or Log. Your ears hear loudness in a logarithmic fashion. I usually find these on volume pots. B = Linear, I see these more often. Doesn't matter THAT much if you swap, but you'll be compromising your control (harder to dial in the "right" amount if a little twist makes a lot of difference or vice versa)
2. Usually, the middle one is the base. I then look at the vertical line on the symbol and it corresponds to the flat part of the transistor. NOTE: NOT ALL TRANSISTORS HAVE THE SAME PINOUT FETs have funky pinouts, I find.
3. Its the one with the circle. Numbers go around it.
Good luck, enjoy
itchyfingers
Cool, thanks Phil!
I'm cool with your answers for 1 and 2, still sorta befuddled about the IC.  So if the circle is 1, then do the numbers play out over the other pins like a clock -
1  2
8  3
7  4
6  5
or do the numbers go down one side and up the other?
1  5
2  6
3  7
4  8
phector2004
counter-clockwise
http://www.kpsec.freeuk.com/components/ic.htm
but I usually just look at the datasheet, and it shows which actual pin does what
itchyfingers
Figures, the one configuration I didn't think of!  Awesome site, btw.  Thanks again Phil!
JKowalski
Quote from: phector2004 on July 13, 2010, 07:49:17 PM
Bipolar transistors and MOSFETs are in the order COLLECTOR/DRAIN, BASE/GATE, EMITTER/SOURCE
JFETs go in the order gate, source, drain.
These are often flipped 180 degrees for different transistors (you can't always tell by using the rounded/flat side as a reference) So be careful.
Power transistors are different.
Power bipolars/MOSFETs are usually in the order BASE/GATE, COLLECTOR/DRAIN, EMITTER/SOURCE from left to right looking at it from the front.
Knowing this speeds up the PCB making process since you can (usually) put down your transistors without checking the datasheet first - as long as you know which terminal the middle is. After you make the board, you can put the transistor in either way, so you then take a peek at the datasheet. Unless you bought some really funky transistor.
REMEMBER, there are always exceptions to these pinouts
phector2004
yup,
2SK117's are Source-Gate-Drain  :icon_confused:
gotta rewire everything if I wanna swap in a J201
Also a neat observation for pots:
If you're looking at it with the shaft up and the tabs facing you, you can number them 1,2,3 going left to right. When you turn the wiper clockwise, you're lowering the resistance to terminal 3 (the top one in a schematic), and bringing it counter-clockwise you're increasing the resistance to terminal 3 (lowering the resistance to terminal 1, the bottom one in a schematic.
Hope that makes sense, I still sometimes wire them backwards!
itchyfingers
That does make sense.  I am still having a tough time in my head of seeing "through" the board / schematic, but I am learning!  You mention the "bottom lug in the schematic" being #1, and that got me to thinking.  I've seen a few schematics that call for an electrolytic cap to bridge the lugs on a pot sorta like this guy:
Based on what you said about terminal 1 being at the bottom in a schematic, is it safe to assume the 47uF electrolytic cap should connect lugs 1 and 2 of the 5k pot since its at the lower end and middle of the resistor symbol?
Again, thanks for all your help, guys!
phector2004
yup, so looking at it from the bottom, it should connect + side to the wiper (middle) and - to the 1st lug (right one looking at it from the bottom side, facing you)
Ice-9
Transistors and Fets have many different pinouts so its best to look up the datasheet for specific pinouts.
www.stanleyfx.co.uk
itchyfingers
Phil - thanks again man, I appreciate the guidance.
Ice-9 - do you have a website you use to check these datasheets, or do you just google the transistor or FET name?
kaboom
Hey! I recommend http://english.electronica-pt.com/db/cross-reference.php?ref=AC139 (yeah, that's an example of the AC139) .Some parts are in spanish but the important things aren't ;)
edvard
Yes, Googling for parts numbers works pretty well, but http://www.datasheetarchive.com/ has had 90% of what I needed to find, so you might as well start there.
itchyfingers
You guys kick major ass!  Thanks for all the help.  :icon_mrgreen:
Ice-9
Quote from: edvard on July 15, 2010, 02:32:44 PM
+1 on the datasheetarchive, i use it all the time
www.stanleyfx.co.uk
newfish
+1 also on Datasheet Archive.
Add it to your internet favourites list and you won't go far wrong.
Happiness is a warm etchant bath.
edvard
Lately http://www.alldatasheet.com seems to be a help as well.
Now you're armed to the teeth...
IvIark
Quote from: itchyfingers on July 14, 2010, 06:41:15 PM
All that scheme is really telling you is that both lug 1 of the pot and the negative leg of the capacitor are connected to ground.  Some people don't like connecting components between the lugs of the pots especially for a value like 47uF which could be a physically large capacitor, so if you were making for instance a vero layout based on that scheme, you could put the cap on the board with the negative leg on the ground rail, and then wire from lug 2 to the row you put the positive leg of the cap.  And lug 1 of the pot would be connected to any point of ground.
