Author
Topic: iRig (with DIY impedance matching cable?) (Read 65623 times)
mat
Matti T.
The Amplitube iRig (link to the free version: http://itunes.apple.com/us/app/amplitube-free/id373309342?mt=8) seems like a great practise tool. The basic app for iPhone is free, and the iRig connector seems to be reasonably priced also but we have to wait for them for quite a while to come to the music stores (at least where I live). I was thinking how to make one. Here is what the IK multimedia worker wrote: There's impedance matching going on, yes, and it is possible for DIY but not a super simple thing to be honest. It will get the right signal into the iPhone/iPad/iPod Touch and the latency will be minimal (just like the PC/Mac AmpliTube products). This isn't a 1:1 port of AmpliTube 3 of course, due to platform requirements and such but it does sound really great.
Thanks for the kind words and questions and I really do hope people enjoy this. _________________ Peter Toriello Community Support IK MultimediaI can build the cable (the iPhone miniplug connectors are towards the tip: mic,ground,left and right) but would like to know how to match the guitar to iPhone impedance ? Someone wrote that the guitar signal should be padded down for it being too hot for the iPhone. One user video (not bad sounding IMHO): http://www.youtube.com/watch?v=VnOUQNm2zQAMat
Logged
Skruffyhound
Is this schem for iRig ? I'd like to know that and if anyone has verified it. Thanks anyway
Logged
rafaeldmachado
Hi all,
Hey mat, can you post a photo of the bottom layer of your iRig?
Thks!
Logged
waaap
Is this schem for iRig ? I'd like to know that and if anyone has verified it. Thanks anyway this schem is verified by many of japsnese. this isn't for irig at exactly, but almost same as it.
Logged
BoxOfSnoo
Jonathan M. Halifax NS
Those seem kinda complicated... how do they compare to this one?
Logged
My Dropbox referral link - bonus 250MB of space for both of us if you use it
Paul R. - Maine USA
> This help you http://ideofunk.up.seesaa.net..... Q2 has no gate resistor so its bias is uncertain. I don't see why Q2 is needed at all; we have too much signal, why 2-stage amplifier? >> compare to this one? > distortion is often a problem Yes, turn-down the guitar. The mike input is probably scaled for 20mV-50mV maximum input, guitar runs up to 200mV even 500mV. You need loss, impedance, and you need DC isolation because there is DC coming out of the iFone to power typical electret mikes. The " this one" plan isolates DC from the guitar, and has impedance to spare, but will overload either in the JFET or in the iFone. Put a hi-Z pot in _front_ of that.  Pot may be 250K or 500K. Lower will suck the top off the guitar, and higher will add hiss. I bet the pot wants to be Audio taper because we want about 10:1 loss in "normal" setting and with audio-taper that will be near "5". You may use linear but the "normal" setting will be near "1" and pretty twitchy. It would be "better" to run the JFET with more supply voltage than what come out of a iFone, but that means a battery.
Logged
FiveseveN
over the top
I don't see why Q2 is needed at all My thoughts exactly, but I was hoping someone with more experience/knowledge would jump in. Seriously, woy would a manufacturer opt for that configuration (other than the negligible high-pass between the stages)?
Logged
Ignorance more frequently begets confidence than does knowledge. (Charles Darwin)
waaap
I don't see why Q2 is needed at all My thoughts exactly, but I was hoping someone with more experience/knowledge would jump in. Seriously, woy would a manufacturer opt for that configuration (other than the negligible high-pass between the stages)? The author of this schem says "Signals is unstable with one FET. With two, it seem to be OK"
Logged
rafaeldmachado
Is the circuit proposed with two FETs the actual one implemented on iRig? Has anyone tested it yet?
On the photo from mat it seems that iRig has only one FET/JFET.
I'd like to do some reverse engineering on iRig, but it is unlikely that I can put my hands on one right now. Is there a volunteer here?
Logged
mat
Matti T.
I can only see one fet/transistor. If anyone wants I could measure the components if need be.
Logged
Skruffyhound
To measure resistance you would normally have to pull the resistors out of the circuit and you probably don't want to do that. Perhaps you could just give us a list of component values next to their assignations. R1 172 ohm, etc. With that and the photo's it should be possible to figure out the schem. It's not a very large circuit. This may be of assistance : http://www.marsport.org.uk/smd/mainframe.htmThanks for the info so far. - Aston
Logged
mat
Matti T.
To measure resistance you would normally have to pull the resistors out of the circuit and you probably don't want to do that. Perhaps you could just give us a list of component values next to their assignations. R1 172 ohm, etc. With that and the photo's it should be possible to figure out the schem. It's not a very large circuit. This may be of assistance : http://www.marsport.org.uk/smd/mainframe.htmThanks for the info so far. - Aston Here is a picture with the values of the components that had markings on them: http://mattitee.kuvat.fi/kuvat/iRig%20top%20values.bmp/full
Logged
forumpineapple
I'm a new member of this forum. I just want to share my opinion about the circuit of iRig. After watching the circuit of iRig, I compare with some common pre-amp circuit of the guitar, it should be a JFET. Here is one: http://www.till.com/articles/GuitarPreamp/Besides, the circuit inspire me to make a BJT common collector circuit to make a pre-amp (because I only have BJT...). Although the circuit worked, the result seems no good. The signal seems clipped even I set all the things "bypass" in Amplitube. But when I examine the input signal, on clipping occured. So I need to further study the problem is from BJT or another reason.
Logged
Skruffyhound
Thanks Matti, I'll see if I can have a look at it over the next couple of weeks. - Aston
Logged
Volume11
Interesting! Bump
Logged
rafaeldmachado
Hi there! I drawn the iRig circuit as it follows: http://picasaweb.google.com/lh/photo/QNC5BuVyD2spITZPptI44AIt is a simple amplifier / impedance matcher with some filters incorporated. Some things to point: 1. WTF are the components marked as FB? Circuit breakers? 2. The variable resistance needs to be better specified if we want to replicate this circuit. I don't know how to do it. 3. Can someone read the code for Q1? Is it a JFET, MOSFET or what? 4. Can someone measure what are the pins in P2 jack? 5. R1 = maybe a jumper (?); R2 = 39 (?); R3 = 1k2 (?); R4 = 4k2 (?) 6. The capacitors C1 and C2 form a band pass filter. Can someone specify those using filters theory? 7. C3 is also meant to filter high freq signal. For its acurate calculation we need to know what semiconductor Q1 is. If someone is willing to give a try and build a prototype using this topology, give us feedback.
Logged
