simple chorus build
Started by mhartington, August 03, 2010, 12:32:49 AM
mhartington
I got a GGG pt80 delay that i want to rehouse and add a chorus for some modulation. Are there any one knob choruses out that could do this.
chromesphere
I think the zombie chorus is probably the easiest one i know.  Unfornately it has 2 knobs and a switch.  Not sure if you could maybe hide the switch inside the box, and use a trim pot for depth or speed?
http://www.geofex.com/PCB_layouts/Layouts/zombie.pdf
Hope it helps.
CS
Pedal Parts Shop                Youtube
mth5044
You could just modulate the delay. Sounds awesome and is super easy. Depending on the LFO, you could have any number of knobs.. typically depth and speed are used, but maybe you could just use one depth knob and add a speed switch?
Philippe
Quote from: mth5044 on August 03, 2010, 07:32:55 PM
*an EH Small Clone?*
