Switch wiring for no 9V clip, just DC jack
Started by glesconz, August 07, 2010, 11:15:08 PM
glesconz
Hi, this may sound dumb, but I intend to build 3 devices (input - compressor - OD - Fuzz - output) in one box, with a single 9v supply (no batteries) powering them all. Assuming this would be ok, would I just omit the battery clip between the input jack ring and +ve rail on the PCB?
I would see what the current draw is for each unit and make sure the power supply can easily handle the total..
Thanks for your help
Glenn
anchovie
Quote from: glesconz on August 07, 2010, 11:15:08 PM
Yes.
glesconz
jkokura
You can use two mono jacks instead of one mono one stereo if you prefer.
Jacob
  DMM here 'n there +/- go...where [ok?
  And there is no continuity between +/- ?
  One of the two, + Or - [the correct one for the polarity used] does and the other doesn't connect to ground.
  In both jack conditions [plug in / no plug].
  Then the circuit / power supply conditions are probably be ok, worth a check.
