|AMPAGE| |GEOFEX| |AMZ|
May 19, 2013, 01:13:23 AM
890667 Posts in 97538 Topics by 28664 Members
Latest Member: jetmarshall
Home Help Login Register
DIYstompboxes.com  |  DIY Stompboxes  |  Building your own stompbox  |  Pictures  |  Anatomy of a Skull 0 Members and 1 Guest are viewing this topic. « previous next »
Pages: [1] Go Down Print
Author Topic: Anatomy of a Skull  (Read 1933 times)
LucifersTrip
^^ Fuzz Skull ^^
WWW
Anatomy of a Skull
« on: August 19, 2010, 04:18:55 AM »
A bunch of people asked me for some more details of my 666 entry ...especially what it looked like with the eyes lit up. [I never took any great shots since I literally finished about 10 min before the deadline].  Actually, the reason I came up with this is because I wanted something to look demonic from the spectator's POV in a typically dimly lit crowd.
In the past, I've circuit bent a ton of small plastic toys and had to navigate small passageways and lack of room. I had to bend wires around corners, carve away edges here & there, but this was way tougher. I will never do something like this again.
I never planned that the only way to build this Skull was to solder all the parts together first (The board, 2 jacks, 3 pots, 3 switches, 2 leds & the battery connector) and then cram it inside a 2 3/8" diameter hole. Since the 666 comp, I actually added 2 more controls, so I actually took it apart. Sadly, I had pics of all the parts before the cram job, but the camera crashed & I had to reformat after I put the pieces in. Just imagine trying to fit & fasten 8 components in all different directions without twisting off a joint. I dread the time when one solder joint vibrates loose...
Inside [it's almost impossible for me to get a good shot of everything through the small hole]:
I like to play in the dark:
Back to the light [still haven't decided on what knobs, if any I will use]:
Logged
always think outside the box
skatman
Paul
Re: Anatomy of a Skull
« Reply #1 on: August 21, 2010, 06:10:41 AM »
This pedal rocks , just love the look and the idea never seen anything like that before would look arwsome on stage !!!  - cheers Paul  icon_twisted
Logged
LucifersTrip
^^ Fuzz Skull ^^
WWW
« Reply #2 on: August 21, 2010, 02:25:40 PM »
This pedal rocks , just love the look and the idea never seen anything like that before would look awesome on stage !!!  - cheers Paul  icon_twisted
Thanx...it was a blast!...tho, if you ever decide to build one, buy an enclosure with a removable parietal or occipital section for easy surgery
Logged
Pages: [1] Go Up Print
« previous next »
Jump to:
