Digital multi-effects unit in Sept10 ELEKTOR
Started by StephenGiles, August 27, 2010, 04:55:15 AM
StephenGiles
radio
Hi
I bought the german version of this monthes elektor. As they state ,it just gets as high as 15kHz ,I assume you could use it
in a guitar-amps send-return, but better not on a mixing desk. However,you can buy a complete pre-programmed kit, it s
really tempting except(for me) one point. How do you solder the SMD processor with "normal" solderstation?
I just never tried it, any advice?
Greets Jean-Marie
Keep on soldering!
And don t burn fingers!
dune2k
I read that wrapping a (copper) wire around the solder iron's tip works. Haven't tried it yet though. :)
octfrank
Frank Thomson
Experimental Noize
Johan
Quote from: radio on August 27, 2010, 05:01:22 AM
Greets Jean-Marie
why not..many, many professional vocal mic's dont go any higher than that without complaints and most people cant hear much above that anyway...
J
DON'T PANIC
radio
@ octfrank: thanks for the link.
@Johan:  I used to have an Boss SE-50 that with 32kHz sampling rate also recorded up to 15kHz
               and I was allergic to it s quality after a while.Fortunatly it  also had  single effects
               at 48kHz sample  rates which were top.
               2 things I didn't consider: I guess the FV-1 may/should have better oversampling
               If you record/convert later to mp3 ,it shouldn't really matter.
Anyway , if their are more arguments  ,I ll be please  to learn.
Regards Jean-Marie
Keep on soldering!
peterv999
Hi
Greets Jean-Marie
Jean-Marie,
I'm puzzled by the fact that a guitar's bandwidth is within the 15Khz range I think. Is is correct to assume this 15Khz is outside this discussion for guitar?
Also, The German design is without preamp as it's designer is a keyboard player.
Regards. pieta
radio
It s good to remind it has no preamp.
But you simply misunderstood my point!
I said it was ok for send-return,so why should I assume it s not good for guitar?
For instance if you buy the new engl gigmaster 15 that has no reverb ,it should be useful.
I d never use digital effects in front of the amp even line 6 but that s just a matter
of taste. A disadvantage of many elektor projects for musicians is that they are not
designed by/with the help of musicians.In my opinion non of their distortions need to
be build. In this case they ve done better.
As for the soldering of smd ,I was send a link meanwhile:
http://www.youtube.com/watch?v=5uiroWBkdFY
JM
Keep on soldering!
