Question about 12AX7 tube driven OD/Distortion/Amp
Started by Govmnt_Lacky, September 05, 2010, 05:47:18 PM
Govmnt_Lacky
I am looking into possibly building up a 12AX7 based effect. I have seen the Shaka but I am really interested in building something else. Maybe a pre-amp or another OD/Distortion.
This is a solicitation for suggestions, comments, and links to projects.
Thanks  8)
anchovie
Do you feel comfortable/confident about working with voltages that could kill you?
Govmnt_Lacky
Quote from: anchovie on September 05, 2010, 06:14:38 PM
I don't know.... Can this thing put out 200A at 400Hz? If not then I think I will be OK.
Any ideas?
Govmnt_Lacky
The inconvenient BUMP  ::)
Any ideas for a tube-based OD/Distortion using 12AX7 tubes? I have 3 on hand to play with.
merlinb
If you're willing to build a small, high-voltage supply (a la Real McTube), then you could feasibly copy just about any existing valve preamp schematic you care to mention.
davidallancole
Govmnt_Lacky, I get a feeling from your reply you are in the electrical industry?  Just remember that there is voltages here in tube circuitry that can kill you.  It doesn't take much.
Govmnt_Lacky
Quote from: merlinb on September 14, 2010, 12:39:49 PM
Thanks. Do you have any links to PCB layouts. I know of the Shaka but not many others. I dont do vero or perf but if you know and PCB layouts then that would be great!
Quote from: davidallancole on September 14, 2010, 01:33:34 PM
I am well aware of this. I will take the necessary precautions.
Govmnt_Lacky
Ok... Now that I have been WELL informed about the dangers of working with HIGH VOLTAGE tube-based projects, bring on the suggestions and layout links!  :icon_biggrin:
defaced
Merlin already gave you the best answer.  The question is more not what's available, but what are you after?  Once there's a target on the wall we can start throwing darts at it.  What kind of music do you play?  What kind of amp is this going into?  All of this stuff will help you get meaningful suggestions.  But less that, I think you should use all three tubes and build a Soldano SLO style high gain circuit.  Why?  Because it's what I just finished building.
-Mike
Govmnt_Lacky
Quote from: defaced on September 15, 2010, 02:51:39 PM
What is this High Gain device that you speak of? [typed with eyebrow raised]
You have peaked my interest since I am definitely interested in some high gain crunch!
Could you provide details or a layout? PCB perhaps??
defaced
Doing homework on this one is easy.  I'll leave all that fun stuff to you.  All of the information is out there if you use Google, including my turret layout for the OD channel only.  All you want to do is Clone the SLO
-Mike
tubelectron
Hi Govmnt_Lacky,
Let's suppose you are OK with 250V plate voltage and want to stay with a simple design, with only one 12AX7.
For a Hi-gain overdrive pedal, the Westbury W-20 works well (I have one, mint-condition, made in 1980) :
For a subtle-to-vintage-to-medium-gain overdrive, my tubelectron overdrive II is worth to try :
In both case, I would now recommend a DC heating of the 12AX7, for a better hum quietness.
A+!
I apologize for my approximative english writing and understanding !
http://guilhemamplification.jimdofree.com/
zambo
I got to tell ya, I have been having a LOT of fun inventing or butchering and hacking designs on my own. If you just look at most pre amp schematics they are all very similar. Just take three tube sockets and cascade them together running 100 b+ volts with 1 meg pots between stages and a 1.5 cathode resistor to start. See where that goes and have fun tweeking it over about 3 weeks. Who knows, maybe your design is the next one we will all want to clone.. :icon_wink:
I wonder what happens if I .......
