Author Topic: tiny tremoloOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO  (Read 239591 times)
Re: tiny tremoloOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO
« Reply #640 on: March 23, 2011, 08:52:34 PM »
hmmmm...im sure it would have to be between the in/out  and the switch....hmmmmmm......
maybe someone more knowledgable could chime in here on this.. :icon_wink:
glad your enjoying it though...cool. its nice to hear success stories on this...nice one .. :icon_cool:
i'm busy at the moment trying to suss out a sine wave schematic for my other current project...the 'pulsewah'....cant wait to get it going/finished..i love the sound of it.. :icon_twisted:
check it out...i built one on pcb..but the @#$%er ticked...so am approaching it from a different lfo..pulse..i'll get there one day...like the tiny trem these things take time to get right...ish.. :icon_mrgreen:
http://www.diystompboxes.com/smfforum/index.php?topic=88582.0
http://www.youtube.com/user/100roberthenry
http://deadastronaut.wix.com/index
^ SPACE PATROL FUZZ/ NANO-8 MIDI DRUMS /CHASM REVERB / TREMSHIFTER / FAZE FILTER/ABDUCTOR II DELAY pcb's + WAH LIGHT PLATES. and sausa
Ratbones
« Reply #641 on: March 25, 2011, 02:58:21 PM »
So I've got this all thrown together finished and in an aluminum hammond style enclosure, but with a 4069 triangle wave LFO.
I've got a very quiet ticking and buzzing, which sucks... (Probably inherent in my LFO choice; I should've just gone with the 555 LFO). Anyhoo, I'm wondering what proper preocedure for enclosure grounding is. If I touch bare metal on the enclosure, it buzzes, which makes me think maybe I should ground it. This is my second pedal, so I'm new to this, and I've never really heard whether enclosure grounding is proper or not.
Advice?
pinkjimiphoton
  • Poster2
  • Total likes: 300
  • High priest, Cult of Germanium, and Dudeist Monk
    • odds are i'm probably banned  here...
« Reply #642 on: March 25, 2011, 04:32:57 PM »
hey bro, just ground the circuit  to the ground lug on one of the jacks, and you should be good to go...and, if it's anything like the one i built, that should take care of the ticking, too..good luck! if ya still have issues, and are in the states, go to rat shack and get the proper 555, and you should be good to go! be careful, rat shack stocks two of them, both cmos, but only ONE works right in this circuit...it's somewhere on this page, maybe the one before it.
have fun!
digi2t:
"Fuzz, distortion, and wah, are plenty abound. Mutron Flanger, not so much.  8)"
#FuzzyGoodness
« Reply #643 on: March 26, 2011, 12:53:35 PM »
@drew, yeah ive tried lots of different lfo's on various things...and a lot of them had noise/tick issues..too many too remember... :icon_rolleyes:
stick with the cmos 555 and you should be ok... :icon_wink:
ppaappoo
« Reply #644 on: March 26, 2011, 02:49:46 PM »
HI, if you try to use an audio switch FET instead LED/LDR?
« Last Edit: March 26, 2011, 03:03:13 PM by ppaappoo »
« Reply #645 on: March 26, 2011, 03:00:18 PM »
hi pappoo
sounds interesting, i dont have a clue how that works though...being a dumbass!...could you elaborate?.
would the 555 turn the fet on/off then, and be variable speed controlled too...with a depth also?..hmmm...i think i'm understanding you....a bit!.
ppaappoo
« Reply #646 on: March 26, 2011, 03:17:43 PM »
hi pappoo
Not much about it but I think the EA Tremolo has something similar, is the part shown in red, it seems that Q2 is a kind of switch controlled by oscillator, that leads the signal to ground .
Try this to bypass the signal to ground and cause an sound inrrupcion like a tremolo.
pinkjimiphoton
  • Poster2
  • Total likes: 300
« Reply #647 on: March 28, 2011, 10:13:42 AM »
digi2t:
#FuzzyGoodness
Scruffie
« Reply #648 on: March 28, 2011, 10:21:42 AM »
hi pappoo
The FET Is working as a Variable Resistor... you can't really just take it out that design and stick it in another though, FETs are hard to use and Vary alot so getting them to run predictably and cleanly is difficult, that's why you don't see them used too often.
There are a couple of other options but the LED/LDR combo already in use here provides the simplest and cleanest solution.
« Reply #649 on: March 28, 2011, 10:28:49 AM »
@jimi..yay!...built!.. :icon_cool:
@scruffie...hmmm...not as simple as first thought then!...
Scruffie
« Reply #650 on: March 28, 2011, 10:36:05 AM »
Yeah... i'm gunna say if you had ticking problems with an LED, you'll be in for a whole world of pain with a FET.
« Reply #651 on: March 28, 2011, 10:38:51 AM »
righto!...
pinkjimiphoton
  • Poster2
  • Total likes: 300
« Reply #652 on: March 28, 2011, 02:00:29 PM »
not to be lame/lazy, but if i increase the resistance of the depth pot, will i get slightly more throb?
i added that buffer circuit  i was working on to it, works great, but now the throbulation is really really subtle...but...in a way it's kinda cool, cuz as the guitar decays, the trem gets stronger!! kinda neat in itself, but i'd really like just a rch more to the depth...do you think a 10k or 50 may work better rob? or is it overkill? or do i need to go down, say, maybe to 1k?
thanks in advance!! i love this circuit, it's really sweet and subtle!!
edit...i tried raising and lowering the resistance in the depth part of the circuit, no difference whatsoever.
i'm thinking i'll try wiring it to the output jack instead of the input, but thinking it may pick up a "tick" in the buffer amp?
the only other thought i've got is maybe separating the led/ldr slightly, to see if that may increase the intensity of the pulse?
i await ya'll's infinitely superior knowledge on this!!  ;D
« Last Edit: March 28, 2011, 03:12:29 PM by pinkjimiphoton »
digi2t:
#FuzzyGoodness
Barcode80
« Reply #653 on: March 28, 2011, 05:14:03 PM »
is your buffer set up as unity gain? I ask because if it is set with a small boost, then the resistance of the LDR may not be enough to kill the signal, which would explain your problem.
pinkjimiphoton
  • Poster2
  • Total likes: 300
« Reply #654 on: March 28, 2011, 06:00:56 PM »
yah, unity gain, i've been wondering if it's giving a slight boost. here's the circuit...beats me, i'm a newbe!
i have noticed that fuzzes and drives tend to overpower it...kinda neat, in a way...like a ducking trem! :icon_lol:
digi2t:
#FuzzyGoodness
askwho69
« Reply #655 on: April 18, 2011, 06:17:43 AM »
Hi all! :D rob iwasscanning the thread for hours! hehehe cant find the final schematic :( hooooooooh can you repost it? :D thanks i want to make this tomorrow :D
"To live is to die"
askwho69
« Reply #657 on: April 19, 2011, 12:32:31 AM »
thanks rob ill make a schematic for perfing :D
"To live is to die"
LucifersTrip
« Reply #658 on: April 19, 2011, 02:30:05 AM »
sounds great...please post when you are finished...
always think outside the box
askwho69
« Reply #659 on: April 19, 2011, 06:44:25 AM »
ohhh i wrote it in a piece of paper and then analyse the size and free-styling the perf design hehehe :D
"To live is to die"
