Author Topic: Pedal to USB Question  (Read 3123 times)
cps
« on: October 15, 2010, 01:12:51 AM »
Hi,
I posted this question over on the DIYAudio forum however there hasn't been a response.
I'm a computer programmer (mainly multimedia), and I've dabbled in analog electronics (I've built a couple of valve guitar amps and distortion pedals as well as other music gear). I'm also a guitarist.
I'd like to build a distortion "pedal/interface" that I can use for recording. More specifically, I'd like to add a USB port to the pedal/interface.
I think I'm OK with the pedal and the computer aspects of the project but
I haven't done much in the way of digital electronics - how difficult would this be to do?
I was thinking of doing something like running a runoffgroove amp simulator (Thor?) into their Condor cabinet simulator and then into a TI PCM2906B (?) and finally into the computer via the USB port.
Would this be (a) easy, (b) hard, or (c) forget it?  :icon_biggrin:
Any suggestions?
Cheers,
Chris
km-r
Re: Pedal to USB Question
« Reply #1 on: October 15, 2010, 01:28:00 AM »
i think you can reverse engineer those cheap'n'nasty USB soundcards that usually come from C****
check out these DIY USB soundcards
http://zedomax.com/blog/2008/05/19/diy-usb-sound-card-needs-no-xp-drivers/
http://electronics-diy.com/PCM2706_USB_Soundcard.php
Look at it this way- everyone rags on air guitar here because everyone can play guitar.  If we were on a lawn mower forum, air guitar would be okay and they would ridicule air mowing.
potul
« Reply #2 on: October 22, 2010, 04:13:50 AM »
I think these USB soundcards have a DAC, but no ADC. They don't seem to have an analog input.
But I guess something like a PCM2912A could be used for input.
Not a beginner's project, though.
Potul
Ice-9
« Reply #3 on: November 09, 2010, 05:23:15 AM »
M-Audio who make high quality sound cards for home studio usemake a small USB interface stick which has input and output, I have one plugged into my PC just so i can plug in effects pedals to test. Sound quality is good and there very cheap. Maybe having a look at one of these would be a good start. The interface came free with session software which cost 20.
It's fairly straight forward, if you want to start it , press start. You can work out the rest of the controls for yourself !
Do me a lemon, that a poor IQ for a glass of water.
Ice-9
« Reply #4 on: November 09, 2010, 05:33:33 AM »
I've just opened up the M-Audio interface and it uses a Micronas UAC35568 chip for its usb to audio and it also has a 24cxx eeprom in there and not much else.
here is a link to the controller data, maybe its worth a read
http://www.digchip.com/datasheets/parts/datasheet/656/UAC3553B.php
