pitch pirate schematic
Started by doug deeper, November 11, 2010, 09:54:13 AM
doug deeper
the other dudes have it, so now you can too!
:D
~arph
Cool, I love your laid back spirit on the availability of your schem's If only more builders would follow your example. (there are some.. like catalinbread)
earthtonesaudio
Same here, although I do miss the nearly illegible schematic style you used to do.
~arph
Haha.. well this is quite illegible too   ;D
Slade
Quote from: earthtonesaudio on November 11, 2010, 11:17:13 AM
+1!!
Thanks for the schem, Doug :icon_smile:
John Lyons
You're a "gentleman and a scholar" Doug!
Thanks for your contribution and tact.
Basic Audio Pedals
www.basicaudio.net/
Skruffyhound
Thank you, and er commiserations. Hopefully you have a new bunch of tricks up your sleeve by now.
jdub
Doug, thank you for your generosity. You are truly a class act.   :-*
A boy has never wept nor dashed a thousand kim
Ronsonic
Okay, I'm a dumbass, what is IC3?
Not really concerned except for curiosity about how this thing works.
http://ronbalesfx.blogspot.com
My Blog of FX, Gear and Amp Services and DIY Info
jefe
Has anyone built a vero for this yet? If not, would someone please design one for me?
Kidding!!
Thank you for sharing this, Doug!
rousejeremy
Holy sh*t!
Doug, you're the man.
Consistency is a worthy adversary
www.jeremyrouse.weebly.com
rousejeremy
Quote from: Ronsonic on November 11, 2010, 02:49:33 PM
Probably PT2399
bean
frank_p
Jeremy was right: anything by DD is cool.
Thanks.
Hides-His-Eyes
This is going to be a bitch to vero without using axial electrolytics... Lots of pins going via a capacitor to ground, hard to do neatly.
doug deeper
i build them on perfboard with radials, so anything is possible!  :D
Hides-His-Eyes
Last time I tried to perf something, I got so angry I flung it in the bin and I haven't had the balls to try again since  :D
I had it working (after pretty much a full resolder, and replacing a fried transistor that I'd cleverly put in first and used the legs of to connect everything else) only to find I'd put the pot in backwards.
You try desoldering a pot that has 3 sets 'perflined' to it. >:/
nick d
                 Vero , perf , whatever ....... I am doing this !  Remember - measure twice , cut once . If  in doubt , check it again .
                   I will build this , it will not work , then I will fix all my stupid mistakes , and eventually it will be brilliant!!
Skruffyhound
nick d
                  Sooooo................  I built it . It didn't work at first ( of course ! ) , so I fixed the 5 stupid mistakes ,
                    and NOW - ( drum roll ..........)  YEAH!!!!!!!
                    It does what it says on the  tin , as they say . On fairly mild settings , it is quite musical -
                    start turning things up , and......WTF !!!!!!
                   I recommend anyone with a taste for the bizarre to have a go  !!!
