Tillman preamp
Started by bassmannate, November 21, 2010, 06:03:25 PM
bassmannate
Since this circuit is so simple and small, I'm thinking this would be great to put in the control cavity of my bass! Obviously, the simplest implementation would be to just put it between the control pots and the output jack, but what other setups have you guys done with this preamp? Just getting some ideas.
Quackzed
i'd put it after the pickup selector but before the control pots, that way the guitar volume pot acts as the tillman volume pot, no need for 2 volumes... as well as having a tone pot after it...
newfish
You could use a DPDT push/pull pot to bypass the pre-amp.
Then if you ever wanted to record / gig directly into another pre-amp, you'd have the choice of which one to use.
It's also a fail-safe if your battery dies mid-gig or whatever.
...and it's still only two pots!
Happiness is a warm etchant bath.
bassmannate
Well, the only problem is that my bass is currently set up with 2 passive EMG select humbuckers running into separate volume controls. I have VVT right now. I might eventually get a blend pot and replace one of the volume pots but it's more trouble than I want to deal with since my cavity is really small. Makes rewiring inside pretty difficult. I may just build the tillman into a mint tin and use a short patch cable to run from the output to the preamp.
Oh well. It's all still just thoughts as I still have a couple projects that need to be completed first.
Barcode80
It's so low current and simple to build, I personally would build a preamp for each pickup, placed between the pickups and the volume pots. The circuit is low current enough that running them both is not going to run your battery down any faster. Also make sure you work in the battery space needed when laying it out.
Paul Marossy
Quote from: newfish on November 22, 2010, 09:42:51 AM
That's what I did when I had that circuit in a couple of my guitars. And I also liked that a dead battery wouldn't derail me, too.
anti-idiot
Quote from: Barcode80 on November 25, 2010, 02:26:06 PM
That's what I did. 2 preamps, one for each pickup, and they were pot-mounted (ala EMG). Great and simple preamp.
If I was God you'd sell your soul to...
