Student budget valvecaster
Started by Jule553648, January 16, 2011, 07:20:56 AM
Jule553648
I built this for total of 8$ and parts laying at home.
Still don't know the good way to make labels.
Yorick
That looks awesome!
What is that pedal on the background with the led display?
Manny
Very nice indeed.  :)
I think i'm going to put one of these together soon. Did you try both single and double versions or did you go straight for the double?
Jule553648
Quote from: Yorick on January 16, 2011, 09:27:04 AM
That looks awesome!
That is my homemade FV1 multiefect. The display shows which program is engaged. Awesome pedal.
I went straight for the double. But I put in the switch to choose only one tube or both.
Here are some sound clips.
tube valvecatser  c.mp3
0 - 0:30 - 1 tube
0:40 - 0:58 1 tube crunch
0:58-1:35 2 tubes overdrive on minima gain
1.38 --> high gain, but some strange compression occurs so it sound crappy. But i don't play at such high gain.
clips dont work?...no access...
looks good though!. :icon_wink:
Jule553648
blooze_man
Nice, dude. If you read this: http://www.diystompboxes.com/smfforum/index.php?topic=60421.0  it tells you where you can upload clips on Aron's site.
Big Muff, Trotsky Drive, Little Angel, Valvecaster, Whisker Biscuit, Smash Drive, Green Ringer, Fuzz Face, Rangemaster, LPB1, Bazz Fuss/Buzz Box, Radioshack Fuzz, Blue Box, Fuzzrite, Tonepad Wah, EH Pulsar, NPN Tonebender, Torn's Peaker...
Jule553648
clip:
http://www.aronnelson.com/DIYFiles/up/tube_valvecatser__c.mp3
Excuse my playing. I am still a beginner.
0 - 0:30 - 1 tube
Manny
Sounds good, It may need some debugging to get both tubes working at higher gain, I know quite a few people have had trouble with this.
I like the sound of both tubes at low gain though  :)
DavenPaget
Quote from: Jule553648 on January 16, 2011, 07:20:56 AM
How did the tube glow white like a LED ? O_o
Hiatus
tasos
It actually is a led....
If you buy a 9pin tube socket pretty much everyone of them has a hole in the middle that is not used for our projects-tubes....
So you just stick a led in there and there you have it! ;D
http://kukaudio.buyer-buying.com/kukaudio.co/tube-socket-9pin_2017311.jpg
DavenPaget
Quote from: tasos on November 09, 2011, 08:31:49 AM
Yep , i got it , i should get a cheap arc rect tube ( is there any tube cheaper then a 12AX7 but around the size ? ) and then stick a blue/white led  :icon_mrgreen:
MOJO FACTOR .
I must mention to get the 12AX7/EL34 or any triode/pentode tube filament glow , one should try 3mm orange's and red's .
Hiatus
CynicalMan
Quote from: DavenPaget on November 09, 2011, 10:27:52 PM
MOJO FACTOR .
Put out an request for broken 12AX7s on the Buy/Sell forum. You could even offer $2 to sweeten the deal, still cheap enough.
DavenPaget
Quote from: CynicalMan on November 09, 2011, 11:01:42 PM
MOJO FACTOR .
Good call ! I MUST try that , just that i don't know how the shipping thing here works :(
Hiatus
