Daphon E10AD with V3205/NE5532 chip
Started by au_loki, January 17, 2011, 04:02:49 AM
au_loki
Just upgraded my E10AD (bought without an enclosure) with a Cool Audio V3205 and a NE5532 and now want to rehouse it. I want to know if the E10 series of pedals will fit in the E20 series of metal shells as I can get one cheap. Later au_loki.
au_loki
Just found that I can squish it into a 1590BB if i take off the board mounted power jack and in/out jacks. The board will be on an angle and just fit in. There might still be room for a modulation add-on board too. I will post a couple of photos once it is done. Later au_loki.
wavley
How do you like this thing?  I briefly (about three days) owned an Ibanez soundtank delay that is the same thing years and years ago until I dropped it in my friend's front yard and it never worked again, yes... it was broken by a two foot fall and landing in grass.  I think I still know where it is and I've been meaning to fix it.
Bone is in the fingers.
EccoHollow Art & Sound
eccohollow.bandcamp.com
Scruffie
I had an E20DL (Metal Enclosure) and it wasn't bad, needs a few mods to get it going good but other than that it's a decent Analog Delay.
Did get some Delay bleed through occasionaly though, the switching isn't all that great.
Mods i'd suggest:
Change the 3208 to a 3205
Change the OpAmp (Think I used a LM833... or was it 388?)
Add A 10k Trimmer To Bias it (There's actually a symbol on board, but it has fixed resistors)
Replace R18 & 19 with a 10k Trimmer
Getting parts off the board wasn't all that easy though, small tight pads and unleaded solder.
au_loki
The delay pedal has a bit of a high pitch whine as the delay time is increased but overall not too bad once the delay chip is changed out (V3205 - thanks Smallbear) and a NE5532 or similar low noise opamp is dropped in. I got the pedal without the enclosure for $13 - pretty happy with that. I'll let you know how the rehouse goes. Later au_loki.
Scruffie
Quote from: au_loki on January 21, 2011, 03:46:14 PM
With the bias trimmers, you should be able to remove this.
au_loki
Ah - thanks Scruffie, I see them just near the bottom of the delay chip. Thanks, I will try it. Later au_loki
