Substituting SAD1024 with MN3007
Started by opacheco, January 17, 2011, 08:13:08 PM
opacheco
Hi,
I would like to know how I can do in order to replace (substituting) the SAD1024 with a MN3007???...I know that will need to add some parts to the actual circuit pedal(retrofit board?) but I don't care for this, there is sufficent space for some anothers parts inside!!!....Do someone have a Instruction for that??.
By the way I will appreciete so much if someone let me to know where I can find the Data Sheet for both IC!!!
Thanks a lot,
Opacheco.
oldschoolanalog
Hello & welcome.
This will get you started.
For more info (there is also a MN3007 retrofit for the A/DA & MXR117 somewhere here) Use The Search Function (UTSF).
It is your friend. ;)
Here you will find the BBDementia zip file (scroll down).
Loads of info on the IC's you have mentioned (and then some...).
Mystery lounge. No tables, chairs or waiters here. In fact, we're all quite alone.
opacheco
Quote from: oldschoolanalog on January 17, 2011, 08:39:12 PM
Hello & welcome.
oldschoolanalog,
Thanks for the links....very good info!!....I will use the UTSF for more about the retrofit for that.
Thanks again,
Opacheco.
