Pages: [1]
Author
Topic: I think i am hooked !! i cant stop building valve pedals (Read 5594 times)
snakey
^ there nice. I like those
Logged
Bass Player!
tubelectron
Bruno G. - France
Nice job, indeed - are those HV or LV plate supply ?
A+!
Logged
skatman
Thankyou - they are all low voltage plate supply 12 Volt DC
Cheers Paul
Logged
jazbo8
They are beautiful! But, what are they? OD? Any gut shots or schematics?
Jaz
Logged
Earthscum
Jaz
OD/Distortion would be the best guess as to what would possess someone to put a vacuum tube on the floor and kick at it with their foot. Also, I don't think you'd really be shooting for a clean pre-amp with a plate voltage of 12V...
Logged
buildafriend
Dude, very cool stuff. What was your first valve project? Could you suggest a simple one?
Logged
Tacoboy
And then the Dual Valvecaster... 1st valve = 12AU7, 2nd valve 12AT7 Running at 12 volt...   Sounds amazingly good in combination with my Gibson SG and my JCM800 stack... Very solid and powerful sound...
Logged
Let's have phun!
Gurner
Tacoboy excellent build...good design - abolutely shocking graphics (it's like you gave up & thought ..."F*%*, I can't be bothered anymore...now where did I put that massive felt tip pen?")
« Last Edit: September 23, 2011, 10:48:18 AM by Gurner »
Logged
zambo
Greg F. - California, U.S.A.
I love that pedal. Sharpies are the best thing ever invented for graphics imho  nice work!
Logged
I wonder what happens if I .......
Tacoboy
@Gurner: you're exactly right! It works, so why bother about the graphics?
Logged
Let's have phun!
Thomeeque
Tomas, Prague
But you should definitely bother about proper tubes protection, none of these pedals (although beautiful they are!) is ready for the floor use.. They are little too high too, I'd try try to sink those tubes inside a little (you may once want to add it into some pedalboard or rack bay or something, where internal height is limitted to common pedal dimensions)..
T.
« Last Edit: September 26, 2011, 07:10:44 AM by Thomeeque »
Logged
Tacoboy
I've done several (very wild) gigs on stage, and no problem whatsoever. Always carrying some spare tubes, of course
Logged
Let's have phun!
DavenPaget
Dave.S / Dave Seether
I've done several (very wild) gigs on stage, and no problem whatsoever. Always carrying some spare tubes, of course  Granted , how did you make the tube's glow ?!
Logged
Hiatus
tasos
I've done several (very wild) gigs on stage, and no problem whatsoever. Always carrying some spare tubes, of course  Granted , how did you make the tube's glow ?! Pretty much all 9pin tube sockets have a hole in the middle....probably for using it with different tubes?  Anyway...you just put a led in there and that's it!
Logged
DavenPaget
I've done several (very wild) gigs on stage, and no problem whatsoever. Always carrying some spare tubes, of course  Granted , how did you make the tube's glow ?! Pretty much all 9pin tube sockets have a hole in the middle....probably for using it with different tubes?  Anyway...you just put a led in there and that's it!  A hole ? Wow , i believe i can stick a cheap arc rect tube complete with a blue LED , on my power supply if there were holes in them too . or stick a 12AX7 and get a orange LED .
Logged
Hiatus
Tacoboy
Yeah, or try a RGB led...
Logged
Let's have phun!
Pages: [1]
